magnum10's Avatar
EFI conversion
Hello all. I am in the process of swapping my 930 parts to do an EFI conversion. My question is. Do I need my DME (I believe its what it is called) located under the dr seat?
I would appreciate any feedback on this.
Thank you..
Old 09-23-2014, 06:49 PM
GT2BH's Avatar
I've seen people put the DME in different places - it really depends on what is more convenient - if you don't have back seats you can put it under the carpet. Make sure you measure your wiring though.
'09 997 GT2
'86 911 3.2
'83 911 SC (work-in-progress)
Old 09-23-2014, 09:56 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by magnum10 View Post
... Do I need my DME (I believe its what it is called) located under the dr seat?
Thank you..
They are called ECU. You can mount pretty well anywhere in the cabin.
Since I had no functional back seat (due to the roll bar) I decided to build a break box for the 35+ signals and located there.
What systems are you going with?
Who Will Live... Will See
Old 09-24-2014, 02:10 AM
magnum10's Avatar
I purchased the unit from a fellow pelicaner nkowi. I am not very fermi liar with the components of it all. It is still up on the site though. Autotronic is the ecu the rest is Greek to me.
I am concerned that in the swap that I did I may have givin the dme (motronic) box that is under the seat when I may need it myself?? I am hoping that I do not need it with this new system??
Old 09-24-2014, 05:31 AM
E-85 sippin drunk
turbobrat930's Avatar
no, with the autotronic system, it replaces all the stock stuff....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-24-2014, 05:36 AM
magnum10's Avatar
Correction.
The unit brand is autronic, with msd, gsf parts as well.
Old 09-24-2014, 05:46 AM
magnum10's Avatar
That is great to hear.
Thank you for your time. I appreciate it.
I am fairly new to forums but this is a great site.
Old 09-24-2014, 05:49 AM
JJ 911SC's Avatar
Good idea to keep your stock parts just in case...
EFI Conversion for 930 - Sell or Trade for Stock Parts
Old 09-24-2014, 07:42 AM
safe's Avatar
I mounted my ecu in the engine bay against the rear seat wall.
Magnus
Old 09-24-2014, 10:49 AM
Hi Magnum10,
small world, thanks for the turbo/exhaust/intake!
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 09-25-2014, 08:42 AM
