wndsnd's Avatar
My head is spinning, help me sort this out.
I am building a 2.7. I have all the manuals, Tutorials, Books, Spec Guides, etc. I read and read, and read.
I liked the "Complete Sealant Thread" - Henry's list makes it easy. It is hard to believe it takes so many sealants to do a case, but everyone makes good arguments.
Now I am on to the gaskets and seals. I bought the Reintz complete kit, and I see it has the blue case bolt o rings. Well, that won't do, will it? So I just ordered the green Vitons.
My long winded question is, "What others case seals are not quite the preferred, and what should I be ordering?" Basically it is the crank and flywheel seal I am worrying about, based on todays availability.
John
1973 914-6 Conversion
2.7, crank fired, twin plug.
2006 997.1 Carrera S Cabriolet
Old 10-19-2014, 02:40 PM
dtw dtw is offline
GAFB
Send the Reinz kit back unless you already opened it. Get the Wrightwood kit from EBS, Supertec, Steve W, etc.
Old 10-19-2014, 05:47 PM
DSPTurtle's Avatar
If you're asking about the rear main seal, you're fine. Just make sure you install it straight!
Old 10-19-2014, 08:22 PM
wndsnd's Avatar
The rear main seal can be red or black? Any difference? Also the #8 bearing o ring looks like crap compared to old one I removed.
I wish I had seen the Wrightwood kit beforehand.
John
Old 10-21-2014, 06:13 PM
+1000 on the Wrightwood kit. The kit I received for my 2.7 was excellent; it was easily the MOST complete gasket kit I have ever seen for an engine rebuild. I'm over a year past my rebuild with that kit and following the guidance from the engine sealant thread and I have zero leaks.
Old 10-21-2014, 09:19 PM
At the risk of being "flamed", I have two years on my 2.8 twin spark motor. Built using a Reinz gasket set with blue case o rings, zero leaks.
Just careful surface prep' ( flat and clean), deburring of all holes and proper use of sealant.
Just sayin'
Old 10-25-2014, 01:56 AM
Had a Reinz kit for complete rebuild 2011. Done by a "professional". Still not a single drop of oil from the engine. not driven very much though.
Old 10-25-2014, 03:25 PM
