crankshaft ID
Hello. Can anyone help me identify my crankshaft. I beleive it to be an SC crank, but the rod journal size is larger than I read an SC should be. Here is what I measure.
Main dia 60mm
Rod dia 55mm
Flywheel bolts 9
Stroke 70.4mm
John
Old 11-03-2014, 12:15 AM
BURN-BROS's Avatar
John,
It is most likely a 74.4 stroke crank from a 3.2/3.3
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-03-2014, 07:41 AM
With 60 mm mains and 55 mm rods, it could also be a 3.6 crank.
Post a pic and we will be able to tell.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 11-03-2014, 08:25 AM
Thanks for the help guys. I am pretty sure I measure 70.4mm stroke. With the nine bolt flange it must be a carrera 3.0, early 930 3.0, or SC crank. I read SC rod journals are 53mm. I will check on my math again and work on the pictures.
John
Old 11-03-2014, 02:13 PM
A 3.0 from. A Carreras 3.0 uses a 6 bolt flywheel, 2,7 crank.
Old 11-03-2014, 02:54 PM
Here are some pictures. I recalculated my stroke measurments and I came up with 75.6mm
This does not seem that accurate. I expect to find 74.4 or 76.4.
Can anyone ID this crank from the pictures?
I measured a rod journal width. I came up with approx 22.6mm
John
Old 11-03-2014, 03:06 PM
BURN-BROS's Avatar
That is a 74.4 stroke crank from a 3.2
Burnham Performance
Old 11-04-2014, 09:21 AM
