Piston weight marking questions?
guys
i Need 1 piston/cyl . 1-can I use any stock 3.3 or does it have to be with the same weight markings? My original Pistons are (--) the spare ones I have are (++) 2-Is the only difference weight? 3-If I remove a little material from the ++ and match to the -- should I be ok? Thanks Erick Thanks |
Schleprock
Kevin L '86 Carrera "Larry" |
