Lighter 3,0 valves -maybe Ti
Hello guys,
i am looking for some lighter Valves for a hot rod 3,0 engine. At this point I am not sure if standart size (49/41,5) or bigger. I talked to del west. They can make them individual but donīt have them ready. I am sure I have read about people selling them here in the past. But I cannot remember who this were. Any ideas who is selling Ti valves with 9mm valve steam?
many thanks!
Old 12-12-2014, 06:45 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Check with Henry Schmidt at Supertec Performance
Kevin L
'86 Carrera "Larry"
Old 12-12-2014, 09:29 AM
You'll need beryllium-copper seats for them to last and those are not cheap to install.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-12-2014, 04:33 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you do go with the Beryllium-Copper seats...please resist the urge to run your finger around them to see how smooth they are.
Beryllium is poisonous!!!
If it gets into your blood...you are not going to like the result.
A lot of military electronic equipment has thin springy fingers of the stuff on panels to make sure the panel is "sealed" electronically (RF leakage).
We were cautioned very often about getting cut on this stuff.
Bob
Bob Hutson
Old 12-12-2014, 07:58 PM
Bob is spot-on; Berylllium is VERY toxic (lethal) and we wear protective clothing & respirators when machining the seats during installation.
All this adds to the completed costs of using Ti valves.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-12-2014, 10:47 PM
Beryllium Poisoning is quite tricky.
Ingestion of Beryllium is not particularly dangerous and the metal is not poisonous in the traditional sense so it is relatively safe to touch and handle and Copper/Beryllium alloys have been used to make hand tools for use in hazardous areas for many years as the alloys develop good strength but are non-sparking.
The alloy is also used for the manufacture of a significant number of springs.
Beryllium containing alloys are used commonly in the Oil, Nuclear and Aerospace industries.
Where Beryllium is an issue is when fine particles of both the metal and its oxide are inhaled.
Once in the lungs it can be transported by the blood and can have other affects on the liver and other organs but this is uncommon. Its main danger is to the lungs and it can cause severe pneumonia like symptoms and is considered carcinogenic.
Machining Berylium does need some care and the use of high flow rates of coolant and I would always wear they type of respirators used in paint shops but it is not really dangerous to the touch.
http://materion.com/~/media/Files/PDFs/Corporate/FAQs/FAQ108SkinContactandCopperBeryllium.pdf
Old 12-13-2014, 12:14 AM
safe's Avatar
Isn't it better to go with 8 mm stem valves of a more modern design and common alloy such as stainless?
Those are lighter and valve guide replacement are usually needed anyway.
Magnus
Old 12-13-2014, 01:11 AM
Thank you all for your answers! I will send Henry an email. Magnus, are there 8mm Valves that are plug and play? -or do they need to be manufactured?
Old 12-13-2014, 04:55 AM
safe's Avatar
Not sure. A friend fitted some non porsche valves from Manley I think. They were slightly larger so the seat had to be cut.
Magnus
Old 12-13-2014, 06:19 AM
Thank you very much!
Old 12-15-2014, 01:08 AM
304065's Avatar
toyota valves
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-16-2014, 10:20 AM
