gliding_serpent's Avatar
Quick SSI to 3.2 mounting hardware question
SSI's each have a hole on the inner aspect of them where a bolt secures them to the front/middle part of the bottom of the engine.
This article ( Pelican Technical Article: Installing SSI Heat Exchangers on your 911 ) refers to these two bolts. "You’ll note that on both sides of the engine, towards the front on the bottom there is part of the engine that has a small bolt which has nothing attached to it. Take both bolts out. If you trial fit the heat exchanger, you’ll see that the bolt is there to help cinch down the heat exchanger to the engine."
Are these bolts in the 3.2? If they are not, what is the part number, and is drilling required?
thanks
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-03-2014, 05:27 PM
Jeff Alton's Avatar
They are not present, not required.
Cheers
www.turn3autosport.com
Old 12-04-2014, 07:28 PM
Thank you
Old 12-04-2014, 08:30 PM
Cheers
Agree, but I drilled and tapped the boss anyway. Do not make it a through-bolt. YMMV.
Sherwood
Old 12-06-2014, 10:56 AM
