Rear main seal- what brand to buy for 2.2l?
My engine is out of my car and when I took of the flywheel, I saw that the rear main was leaking. What brand of rear main seal is best? Also is there an installation tool available?
My engine is a 2.2l case with 2.7l crank Last edited by tornik550; 12-08-2014 at 05:13 PM.. |
Schleprock
Get the Elring seal. They are better than Reinz.
1970 Porsche 911 E Coupe/Targa - Main Engine Components - Page 1 There is a press-style tool P215 that pushes the seal in nicely. 1970 Porsche 911 E Coupe/Targa - Engine Tools - Page 3 But most people just tap the seal in with a rubber mallet or a PVC pipe fitting.
Kevin L '86 Carrera "Larry" |
If the crank has a deep groove in it from a previous seal...you could look into Chicago-Rawhide's listings to find one that has more than one sealing lip.
Some even have a thin flange to set the depth. Bob
Bob Hutson |
