txhokie4life's Avatar
Intake Spacer for 964 3.6L
I'm looking for a 3 bolt to 3 bolt intake spacer for a 964 engine.
Basically I want to raise the surface ~1/2"
I have an ITB setup and the way that it is now - the nuts which hold the
ITBs sit below the fan shroud and are a real PITA to deal with.
Looking for a spacer to use for this interface -- but not having much luck.
pointers?
thanks,
mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 12-10-2014, 09:05 AM
I'd be tempted to try stainless steel allen head bolts instead of studs and nuts if the nuts are too hard to get at.
Or maybe these cam tower 8x1.25 barrel nuts Part # 901-111-271-00-M100 but 12 0f them would be expensive...
They're on this page part way down: Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Old 12-10-2014, 09:25 AM
No sooner had I sent this out than I thought of the same thing --
just find thicker nuts -- it will require dremel work on the ITBs to make sure there is space to fit them on.
Sadly it's 18 not 12 :-) But still probably cheaper than spacers.
I'll probably source them non-Porsche for a good price discount :-)
Mike
2001 996 GT2
Old 12-10-2014, 10:32 AM
Patrick Motorspors sells phenolic spacers for ITB three bolt heads/manifolds
Old 12-28-2014, 06:55 AM
Went with the thicker nuts and Dremel work
Relatively quick and easy
Thx for all the suggestions
Mike
Old 12-28-2014, 02:06 PM
