txhokie4life's Avatar
LSM-11 O2 Sensor Alternatives
Not sure if this is the forum to ask.
I'm running a 911 3.6 with ITBs and Motec ECU.
My motec system uses an LSM-11 O2 Sensor ==
Trying to find if there is an alternative replacement. The original LSM-11
are a bit spendy.
I'm not even sure our tune is using feedback from the O2 or not, so
I'm a little hesitant to buy a new one at the ~$200+ price point.
The current one is >8 years old.
thx,
mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 12-17-2014, 04:20 PM
Mahler9th's Avatar
Is there some reason to believe that the existing sensor has failed?
The oxygen sensor may not be running in a closed loop (I think this case is likely). If it is not, then depending on your needs, various oxygen sensors may work and be compatible with Motec.
If it is running in closed loop, then my inclination would be to stick with what Motec recommends.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 12-18-2014, 10:25 AM
What ECU? M800?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-19-2014, 01:36 AM
Originally Posted by '76 911S 3.0 View Post
What ECU? M800?
M48. I suspect its running open loop.
I remember the tuner stating the on board O2 sensor wasn't very
accurate and was slow relative to his external. (when it was first tuned
since I rebuilt the engine 3 years ago)
I am in the midst of doing some ITB refurbishment/idle resetting.
Mike
2001 996 GT2
Old 12-19-2014, 11:15 AM
Mike
Can you access the map from the ECU? If you can download it and send it to me I can see if in fact is running in open loop.
-Jayson
IG: Signature_911
Old 12-23-2014, 01:48 PM
Not handy an the moment == but I remember seeing LA CTRL == OFF
mike
2001 996 GT2
Old 12-24-2014, 01:31 PM
