Early 911 question
I have located/isolated an oil leak on my 1971 911T that appears to be where the Driver Side Cam Chain Housing bolts onto the block. I was wondering if it's possible to remove the driver side cam chain housing without removing the engine..
Thanks...
Old 02-24-2015, 06:04 PM
Yes, its possible, but darned clumsy since the muffler, rear sheet metal, cam sprocket, idler, and tensioner all have to removed to get the chain housing off the engine case.
Naturally, you will need to re-time the cam when you are done.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-24-2015, 10:31 PM
Sounds fun.. Cam Timing will require some reading before attempting..
Thanks...
Old 02-25-2015, 06:08 AM
BTW, Muffler, Heat Exchangers already off to attempt to locate the cause of the major oil leak..
Old 02-25-2015, 06:10 AM
Free minder
Aurel's Avatar
I would do partial drop to get more clearance.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 02-25-2015, 04:37 PM
Scheebs
If you remove the 2 bumper guards, then the panel behind the license plate (not really a hard job at all) you will have plenty of room to perform this task. Especially since muffler is already off.
Old 02-25-2015, 07:22 PM
It's 20 degrees in my shop so I'll start this project next week.. Thanks for the help..
Old 03-01-2015, 09:51 AM
