Early 911 question
I have located/isolated an oil leak on my 1971 911T that appears to be where the Driver Side Cam Chain Housing bolts onto the block. I was wondering if it's possible to remove the driver side cam chain housing without removing the engine..
Thanks... Steve |
Yes, its possible, but darned clumsy since the muffler, rear sheet metal, cam sprocket, idler, and tensioner all have to removed to get the chain housing off the engine case.
Naturally, you will need to re-time the cam when you are done.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Sounds fun.. Cam Timing will require some reading before attempting..
Thanks... |
BTW, Muffler, Heat Exchangers already off to attempt to locate the cause of the major oil leak..
Free minder
I would do partial drop to get more clearance.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Scheebs
If you remove the 2 bumper guards, then the panel behind the license plate (not really a hard job at all) you will have plenty of room to perform this task. Especially since muffler is already off.
It's 20 degrees in my shop so I'll start this project next week.. Thanks for the help..
