Aircon
So I bought an engine with aircon compressor installed. is it easy to remove this and do I have to change anything else apart from the drive pulley?
can't use the aircon on the VW Bus it's going into!
Old 02-19-2015, 10:59 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Sounds like you don't have to worry about evacuating any refrigerant so removal is as simple as Take out the bolts and you're done. Unless you have a clearance issue, no good reason to change out the pulley. The (sleeper) bus will surprise a few people!
1986 Targa Guards Red
2021 MT09 SP
Old 02-19-2015, 04:15 PM
Fantastic thanks. Didn't know if I was over simplifying things!
yes, should be a cool sleeper bus. Just need to get the suspension and brakes to the same level as the engine! Thinking of 986 brakes all round.
Old 02-20-2015, 05:01 AM
