smokintr6's Avatar
Send a message via AIM to smokintr6
AC Bracket delete?
Has anyone deleted the cast aluminum bracket for the AC compressor? I have a early 964 3.6 that I'm installing in an 87 carrera, which will not have any AC parts. I would like to remove the cast bracket, but it obviously interacts with the engine mount bracket. Is there a way around this? I considered cutting the upper part of the mount off, but I'm guessing that would be more visibly unappealing than having the empty mount there in the first place.
Thanks!
Old 03-04-2015, 10:23 AM
gtc gtc is offline
abides.
gtc's Avatar
Correct way to do A/C delete?
Graham
1984 Carrera Targa
Old 03-05-2015, 09:51 AM
safe's Avatar
Just cut it of flush with the flat piece thats the same height as the engine tin.
Done it, look good.
Magnus
Old 03-05-2015, 11:31 AM
smokintr6's Avatar
thanks guys, looks like i didn't search carefully enough. Never would have thoight the actual right answer was to cut it off. Some careful surgery is in order
Old 03-05-2015, 01:48 PM
