993 cam tower damage
Are these fixable? or do they need to be replaced?
![]() ![]() ![]() ![]() I don't know the complete history of this engine, but I suspect it suffered a rod bearing failure. This is the second time I have found post engine rebuild that the rebuilder did not take apart the cam towers and debris damaged the journals. The first was on my 951 engine. thanks, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Straight shooter
The last picture is bad... I'd try sourcing replacements to be safe. If you owned a machine shop and could fix in your down time then it might be worthwhile. Paying to fix probably isn't economical.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Replace them.
Those are now doorstops.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks -- that is what I was expecting :-(
Mike
Try not, Do or Do not
We have all kinds of 911 cam towers on the self at 911 Vintage Parts.
760.731.4911
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Straight shooter
Our gracious host sells them, too. $421.50 with warranty.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
