Early Solex cams OK in later engine?
I have a pair of early Solex cams with the center oiling I was thinking of using in my 2,7 rebuild. Is it OK to use these in a later engine with the different oiling set up?
Old 03-13-2015, 04:53 PM
Yessir, it sure is.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-13-2015, 05:57 PM
Get your cam carriers modified to feed the center lube. Love the soles cams
Bruce
Old 03-13-2015, 06:10 PM
Thanks! I thought they would but it never hurts to ask! I've been wavering between the solex cams and "E" cams. euro p/c's,Weber's, 35mm port heads, sport muffler.
Old 03-14-2015, 08:06 AM
Bruce
What else do you need to modify as this seems an interesting idea.
Old 03-14-2015, 09:11 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The sweetest engine ( there were many in 25 years) that I ever built for my street 914/6 was an RS spec 2.7 with Solex cams. The center feed system is really kind of redundant so I would plug the feed end (necessary even if you convert the cams for late housings) and pass on the center feed.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-14-2015, 09:53 AM
Just need the right cam carriers. Last 2.8 I built the soles grind was on 4 bearing cams so I had to use 3.0/3.2 cam carriers.
Bruce
Old 03-14-2015, 02:16 PM
neilca's Avatar
I used a pair of original, three bearing Solex cams in my last race engine. Do what Henry says if they are original.
Old 03-16-2015, 05:38 AM
