-   -   New 2.45 Engine Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/856819-new-2-45-engine-build.html)
lindbhr 05-24-2015 08:56 AM
Subscribed....
Rusty 356 05-30-2015 07:01 PM
Matt, you could have your heads modified for twin plugs, just put a plug in them and twin plug when you have the resoures to go that route.
I love this kind of stuff.
mattC2993 05-31-2015 07:50 AM
Yeah but its only 9.5:1 compression
tharbert 05-31-2015 07:32 PM
I have almost the exact same project going except I'm starting with a 72T case. I also just got my pump redone by Mark to E spec. Henry supplied my p/c's. Did you have him get the pistons calico coated?
turbobrat930 06-01-2015 06:58 AM
sub"ed
Rusty 356 06-01-2015 09:48 AM
I know doesn't seem like it would do anything to add to performance. I owned the 356 Carreras with twin plugs and when I used the kill switches alternately the RPM would drop about 100 rpm. The engine ran a lot crisper with both plugs firing.
Plus the cool factor of twin plug engines.
mattC2993 06-01-2015 05:21 PM
No on the coating. I had to draw the line somewhere and the car won't be driven hard like with track of AX work.
mattC2993 08-15-2015 07:24 AM
Throttle bodies are done now. The long block should be back from Supertec in September.
https://www.youtube.com/watch?v=KSKHoHn6pQQ&feature=youtu.be
jm993rs 08-16-2015 03:34 AM
Subscribed to this thread !! Very cool :)
Hcarraro 08-16-2015 03:12 PM
Subscribed
Harry998R 09-02-2015 04:14 PM
Sorry for the thread hijack but Henry where can I buy this hose (see red arrow in pic), from you?
Thanks very much.
Cheers,
Harry.
http://forums.pelicanparts.com/uploa...1441235636.jpg
Harry998R 09-02-2015 04:16 PM
Hi Matt,
How long did the throttle body restoration take?
Cheers,
Harry.
mattC2993 09-02-2015 05:12 PM
A long time. They received them in late February.
Henry Schmidt 09-03-2015 07:38 AM
Originally Posted by Harry998R (Post 8778504)
Hi Matt,
Cheers,
Harry.
Supertec does concours restorations on MFI throttle bodies and the turn-around time is generally 2-3 weeks. That's right weeks not months.
http://forums.pelicanparts.com/uploa...1441291107.jpg
Henry Schmidt 09-03-2015 07:47 AM
Thanks very much.
Cheers,
Harry.
Unfortunately the brown paper fresh air hose is NLA. Those came from the dealer but now all they have is the black, plastic coated variety. Still looking for other sources but for now we're screwed.
Henry Schmidt 09-03-2015 08:31 AM
It's been a long time coming but the assembly is under way.
http://forums.pelicanparts.com/uploa...1441292826.jpg
http://forums.pelicanparts.com/uploa...1441293300.jpg
http://forums.pelicanparts.com/uploa...1441293411.jpg
http://forums.pelicanparts.com/uploa...1441293525.jpg
http://forums.pelicanparts.com/uploa...1441293628.jpg
Harry998R 09-03-2015 04:32 PM
Thanks Henry, it's a shame as I much prefer the original look, mine have seen better days.
Cheers,
Harry.http://forums.pelicanparts.com/uploa...1441323124.jpg
Harry998R 09-03-2015 04:33 PM
Nice! Time to get excited Matt!
Cheers,
Harry.
mattC2993 09-03-2015 05:26 PM
Alright! Its cooling off here so I'm thinking of all the things I need to do to get that long block assembled. The MFI pump and tb are ready but I need to clean up the fan, tin and exchangers.
mattC2993 10-14-2015 07:21 PM
It has arrived! http://forums.pelicanparts.com/uploa...1444875714.jpg
