Smart quod bastardus
fredmeister's Avatar
930 turbo engine compartment seal
I am looking to replace the rubber seal above the turbo that seals the engine tin to the car body Part # 930-504-170-01-M136 ---cost is $120 or so. It seems like the 911SC uses a different part number that's half the price.
Question: can I use the 911SC seal in place of the turbo seal? I only need the section of the seal directly above the turbo as the replacement long seal also contains both edges that run along the valve covers which are fine on my car and I could trim them off the new part as I don't need to replace these.
What makes the turbo seal different?
thanks guys,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-06-2015, 11:54 AM
Try not, Do or Do not
Henry Schmidt's Avatar
thanks guys,
Fred
It's been a while since I put a turbo engine seal in but if I remember correctly, the turbo front seal is cut away to create clearance for the air pump and belt. The SC seal can be trimmed to work just fine.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-06-2015, 05:53 PM
