Where do 6 copper washers go?
Hi guys with my rebuild kit for the 930 there are six copper washers anyone know where they go? Thank you
Erick
Old 03-25-2015, 03:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Lots of possibility...
What is the size: X x Y x Z in mm
X: Inside
Y: Outside
Z: Thickness
Who Will Live... Will See
Old 03-25-2015, 03:47 PM
Will measure Tomorow. But they are the only cooper washers that came in the rebuilt gasket set . All others are aluminium
Old 03-25-2015, 07:19 PM
Under the injectors.
Bruce
Old 03-25-2015, 07:46 PM
Oh yes. Thanks I am so far off I forgot
Old 03-26-2015, 12:37 PM
Yup, and those skinny little 930 CIS injector copper washers are not easy to find. You can probably reuse the old ones if they aren't squished.
Put a drop of motor oil on the injector threads when installing them and don't over tighten them.
Old 03-26-2015, 01:25 PM
