Really bummed any input appreciated
Just went to start my rebuild turned the motor upside down to undo heat exchangers and found some jb weld, chipped it off and found this. Any input appreciated,I really don't want to buy a new case it's not in my budget.
Old 04-11-2015, 11:46 AM
Under the radar
Trackrash's Avatar
Aluminum case?
If it were my motor, I would do a complete tear-down and make sure nothing else inside was mickeymoused.
I imagine that could be repaired by an experienced PORSCHE welder/machinist.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-11-2015, 11:56 AM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Bummer dude. I hope that can be fixed by weld build up and then parting line machining.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 04-11-2015, 12:00 PM
Looks lik and aluminum case, just continue your teardown and have it repaired by a knowledgible company like Ollie's. They can do Mag cases as well. I just finished a hot 3.0 only to discover that one of the engine mounting bolts in the rear was missing as a result of a broken boss. Guess that one will come down again.
Good luck,
rusty
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 04-11-2015, 12:05 PM
Yes it's aluminum fortunately. I plan on a full rebuild especially after finding this,now I'm not gonna sleep at night. I do know a master welder who welds on helicopters hopefully he might be able to help me, this just ruined my day. I guess I can post this over at the tech board under po poor repairs.
Old 04-11-2015, 12:07 PM
abit off center
cgarr's Avatar
I would have a new thru bolt boss welded in, but set it up and fit it with the case bolted together, tack it then split it and finish both sides, machine it down.
Craig
G2Performance
Old 04-11-2015, 03:31 PM
What kind of aluminum should I use?
Old 04-11-2015, 04:54 PM
Craig nailed it; its quite fixable and such things are SOP on these things. This isn't anything I'd lose a moments sleep over.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-11-2015, 04:56 PM
Thanks for the encouragement I just didn't want to split the cases unless absolutely needed. I'm working on a poor mans budget
Old 04-11-2015, 05:38 PM
Anyone know a good place to get this tig welded and machined in upstate NY I'm new to the 911 world
Old 04-11-2015, 05:39 PM
Well you absolutely need to split the case if you want to repair it. It isn't a big deal to split the case. You may want to check everything and replace the chains and a few other wear items. That part if the case may be a stud rather than a through bolt. Good luck, by the way, you will need a few special tools.
Old 04-12-2015, 08:33 AM
Yeh your right Rusty gonna tear it all down. Bought a torch today hopefully I can conquer the heat exchanger bolts.
Old 04-12-2015, 01:24 PM
Budg et, case gaskets are about $60. And a tube of 574 for the centerline. Then you know what you bought when you can put your hands on it.
Bruce
Old 04-12-2015, 02:25 PM
Anybody know a good place to repair the case? I'm in upstate NY
Old 04-12-2015, 02:30 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Box it up and send it to us. I'm pretty busy right now but I'll squeeze you in.
The trick is not the welding but creating a flat surface when you're done.
I even have an old case I can use the replace the missing flange.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-12-2015, 05:45 PM
Thanks Henry I will do that,I'm just finishing up removing heat exchangers then I will continue tear down.
Old 04-14-2015, 07:06 AM
I would definitely take up Mr Henry's offer.
Old 04-14-2015, 08:10 AM
Mr. Henry ? sound a little like a hair dresser....lol
Henry Schmidt
Ph: 760-728-3062
Old 04-14-2015, 08:46 AM
Or a candy bar for those who prance
Old 04-14-2015, 04:17 PM
