Vendor
Fabspeed Motorsport's Avatar
Location: 155 Commerce Drive | Fort Washington, PA 19034
Nice revival
Hamsa Naser
Hamsa@fabspeed.com
W: +1 267 742 3006
Old 04-27-2015, 06:11 AM
beancounter
jwasbury's Avatar
Originally Posted by KTL View Post
Great use of the muffin tin too I will add that one to my list of garage tricks for sure!!!
^agreed. muffin tin for the win!
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 04-27-2015, 12:02 PM
Straight shooter
Lapkritis's Avatar
Yep - good idea with the muffin tin. I had been using plastic egg cartons but they're a tad bit bendy for my liking.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-27-2015, 12:20 PM
SCadaddle's Avatar
How many miles on this engine?
What did the skirts on the Alusil pistons look like as far as wear?
I ask because I'd be really curious to see one of you guys in the engine building business:
1) Take a well used KS piston from an Alusil set and rub it with a magnet then....
2) Drop it in a bucket of iron shavings and see how much and where it attracts
only so those of us, er, ok, ME! that are running an Alusil piston in a Nikasil plated Alusil bore can at least have 1 data point of just how much iron/tin plating is left on the skirts of a well used piston that makes this combo a "bad idea"!
Old 05-16-2015, 08:58 PM
Originally Posted by Flat6pac View Post
Still needs 574 on seal flanges
What do you do to remove the old sealant on the case mating surfaces and prep for reassembly? Looks rather shiny. Is this an aluminum or mag case? Did the mains need to be line bored thus facing the mating surfaces?
Old 05-18-2015, 08:28 PM
The engine is a mid 80s 3.2. It had been opened before and I had to clean dry 574 sealant from around the studs on the perimeter.
Bruce
Old 05-19-2015, 05:21 AM
Cairo94507's Avatar
Hi everyone- That is my 3.2, supposed to be an '89 that the seller, Ben Merman, another Pelican member, said only had 40K miles on and had never been apart -ever. Obviously that was not the truth. Consequently, I am very glad I decided to take it all the way down and make it fresh. Bruce did a terrific job and I was happy he accepted the job. It was built stock except for the 964 profiled Web cams (20/21) and a Wong custom chip. It will run through my stock Six heat exchangers after they are cleaned and ceramic coated feeing the stock muffler. Thanks again Bruce.
'71 914-6 #0372
'17 Macan GTS
Old 05-25-2015, 07:40 PM
