911SC Engine Removal
Hi All
Its my first time removing the engine in my 1982 911SC, as I really need to replace the airbox due to a backfire. I know you don't HAVE to remove the engine, although i have a Oil Pressure switch leak i believe, coming from the triangle and i figure i may as well just pull the motor and clean up the whole triangle area. Heres my list of things to replace at this time: Oil Pressure switch thermostat O-ring Oil Breather Hoses CIS intake manifold hoses oil cooler seals Adjust the valves or replace Cams with 964 or webcam 20/21 Replace pulley seal Fix heater boxes maybe a stater rebuild? SSI M&K Muffler Wevo motor and trans mounts Also, im thinking while I'm in there ill powder coat the valve covers and all the engine tin as well as the fan. Clean up the motor while I'm doing all this maintenance. Did i miss anything? Now my real question is, I was thinking of dropping the engine and the trans at the same time (3.0 with 915), is this easier than dropping just the motor? I just picked up a set of 46mm PMOs, so i wanted to install those and a set of cams, i haven't found too many great write ups on replacing just the cams, i just know you need the special Porsche P202 tool and the 46mm crawfoot wrench. how difficult is it to time the cams? what cams do you guys recommend? Webcam 964 grind or a 20/21? I've heard they are relatively the same? i have an USA 911SC so, i think i need to port the intake heads to 40mm from 38mm? i can't remember the exact number, but i was told it can be done with the engine on an engine stand flipped upside down. is that ludicrous or doable? thanks for your help in advance! |
Your probably going to find some broken head studs if the dilivar head studs havnt already been replaced. You might as well do the whole motor,clutch et,et,et,. Maybe enjoy the Michigan summer and wait till winter.
i was thinking that too, its not driveable with the cracked airbox at the moment, thats what needs immediate attention to get back on the road.
ill start with draining the oil and pulling the valve covers, but i bought the car 9 months ago and when i had the PPI i had no head stud issues. so, it should be the same still considering it hasn't been driven in 6 months due to winter. |
Under the radar
Do you have Wayne's "How to Rebuild and Modify Porsche 911 Engines"? If not, it is available on this site and a must read.
Ya, I've read it. I was curious if it was easier to remove engine and trans together or separate engine from trans? Is one or the other faster and or easier?
Cheers |
Under the radar
Much easier to remove together. IMO
You probably have the small port heads. I think that 46 PMOs may be a bit large, depending on what cam you plan on using. With the stock pistons, you are limited in what cams you can use. Stock pistons also limit your engine's rev limit to near stock. When porting the heads you need to match the manifolds. You should talk to your cam grinder about your planned use for your motor.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 04-25-2015 at 05:46 PM.. |
Got some progress done today. Rebuilt the heat exchangers, nobody will see these once their in the car, but it needed to be done.
![]() ![]() ![]() ![]() Picked up some new ducting as well, as the old ducting was falling apart. Painted part of the alternator housing as well. ![]() Been cleaning everything, mostly the engine bay right now so, I can repaint it. Incredible how much grease builds up in the engine. Also, cleaning the glue from the sound pad sucks. I was thinking of painting it black, original color is grand prix white. Gonna paint the car back to original color in a year or two, but not for concours reasons. Mostly cause I like white cars. So, white or black? Any recommendations on prep? Bring down to bare metal? Just Bristol pad?
It's a trap...
Cam timing slowed me down on my rebuild (fear?) but once I got into it it was pretty straightforward.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
Stripping engine bay down to bare metal is a huge PIA.
Power wash with a quality detergent is far better than trying to strip paint.
Bruce |
Also, since ill be running carbs now do I just plug my O2 sensor? Or do I continue to use it?
No need for 02 sensor if your running carbs
non-whiner
The alternator and starter are both fairly easy to replace withe engine in the car. I say leave them unless you have an extra $1,000 hanging around.
"Too much is just enough." |
Farrell,
Another suggestion for 'while you are in there' is to replace the fuel lines in the tunnel. I have not replaced mine yet, but I have heard it is a PIA. Can't remember the person's name on this board that makes great replacement lines that are compatible with today's gas, but someone else will chime in with it. Craig
77 Ice Green 911s w/3.0 |
AN-6 Fuel Line Plan for CIS to PMO Carb Conversion Good to hear that the alternator and starter can wait. It was in my cart and around $700 so I wasn't looking forward to that. Happy 4th all! |
Farrell,
Here is a link to the fuel lines I was talking about. You may not have these 'problem lines'. This thread explains things pretty well. Fuel Hoses - 911SC Tunnel to Motor HTH, ![]() craig
So while I wait for my engine harness to come back from Dennis (Timmy2, insane turn around time!
) I stripped the engine bay in anticipation if re painting this. ![]() ![]() It's hard to tell, but this whole trunk was black with grease and crappy spray paint. Now I have read that many people were just having their paint color mixed up, add some thinner to it and then roll it on with a foam brush. With the thinner applied they said it should smooth out and look real nice. Anyone else do this? Paint in this order? Epoxy primer on bare metal Body filler or undercoating for texture Paint Clear Last edited by Farrell; 07-04-2015 at 11:23 AM.. |
I would use a single stage paint.
non-whiner
And use a Preval sprayer. It is perfect for this application and will look great.
