71 t engine info needed
original engine is 6116184 and vin is 911 110 0966 so end of the 71 run . So is engine 2.2 or understand they started 2.4 at end of run.
Thanks for info and were list is posted for engines.
Frank
Old 05-19-2015, 01:29 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Easiest way to tell:
2.0 and 2.2 cranks have two drill holes for oiling.
2.4-2.7 have only one.
Of course this requires that you remove the flywheel to tell.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-19-2015, 01:31 PM
