I think the oversized 964 squirter is the one that was used in the 993 twin turbo engine? |
Henry, I noticed you are running pressure fed tensioners on this engine. I assumed you weren't a fan of these as you prefer the 930 tensioner. What gives?
In the case the engine had relatively new Carrera tensionsers so reusing them seemed appropriate. Whenever possible, I'm a fan of reusing components that offer reasonable serviceability as long as they don't represent an unreasonable compromise to my build. |
What cams are being used?
Fresh off the dyno. http://forums.pelicanparts.com/uploa...1444656754.jpg http://forums.pelicanparts.com/uploa...1444656772.png http://forums.pelicanparts.com/uploa...1444656784.jpg http://forums.pelicanparts.com/uploa...1444656794.png |
As usual, you set the bar high Henry....nice build.
regards, al |
Henry, Great Build as usual. Thank you for continually sharing your special projects with us.
I am curious why there is such a significant increase in torque with the air filters on. These look like ITG filters. As far as I know the top surface is filter material, not hard. I am just trying to figure out what causes the increase in output. Is this an effect of engine break-in from successive runs? What are your thoughts? |
Henry,
I enjoy reading your updates on what you are up to. Thank you very much. Very impressive build and numbers to match. Thanks, Paul |
| All times are GMT -8. The time now is 03:20 PM. |
