Try not, Do or Do not
A special find in a 73"S"
When this engine was removed from it's chassis, a 1973 911 S (with Bromos race history) we were told it was a 2.7 RS. Imagine our surprise when we discovered that the engine was actually a 3.0 RS. A single plug 3.0 MFI engine built on a sand cast RSR 3.0 engine case. In 30 years this is the only one I've ever seen.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Over the next few weeks I'll share the build we did on this very rare engine.
Before ![]() After ![]()
Wow! That would be one time 'non-matching numbers' actually added value!
Look forward to the story. |
Henry ... I saw pics of the headers in another post. where where they source or were they a in house custom job?
Skunk works
Fwooor
That should come with a NSFW warning
964 RS-4 |
gearhead
So cool.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I would rather be driving
Very Cool.
Are the case dimensions the same as the early sand cast case? I realize head stud and spigot are likely larger to accommodate the (presumably) 95mm P/C set.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
wow, Nice find Henry.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
The unique characteristics that are different than the early 2.0 sand cast case is stud spacing half way between between 2.0-2.7 and 3.0-3.3. Very rare. Special heads as well. The other difference is the 5 studs for mounting chain boxes vs 3 studs and 2 pins. The intermediate shaft has thrust bearings similar to what was common on later cases. There are also a considerable number of reinforcements in this casting including a larger base for the cylinder mounting.
signing-up.
Jon |
3.0 engine.......
Very interesting and a real "looker"! Are those Mahle pistons? If so, do you know the compression ratio? Also, what level of horsepower do you expect this engine to make? The pistons look very similar to the Mahle pistons that I used in my 3.3SS build. My set were 10.1:1 compression.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning Last edited by fred cook; 05-31-2015 at 04:32 AM.. |
very neat!
I cant believe I almost missed this.
David 1972 911T/S MFI Survivor |
Very rare engine. What a surprise.
Mark Jung Bend, OR MFI Werks.com |
As we progress, we will post a pictures of the custom injection we built for this project but until then here's the pump you built for this project.
Some Supertec, some Burnham Performance and some MFI Werks magic all came together to produce a very special pump. ![]() ![]() Burnham Performance 1071 Avenida Acaso ste.D Camarillo, Ca. 93012 805-240-6931 rennwerks@hotmail.com MFI Werks 10227 N.W. Swallow St. Seal Rock, OR. 97376 Mark Jung 541-563-3702 info@mfiwerks.com
Very Cool Motor !
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Brumos called-they want their engine back.
