Cam and Head ID Help Needed
I am tearing down my 2.2 that came in a car that I got a few years back to put some new seals in it and I am interested in the parts that were used in it as it was built for a lightweight autocross car.
So, I pulled the right cam out to reseal the cam housing and the cam numbers are 901.5110.1R the end of the cam has an S and a single dot.
The heads are part number 911.104.307.0R and are dated 6-70
I am told it has 10.1 compression but I don't know how to verify that as I am not pulling it down that far.
Anything else I should look at to get a better understanding of what I have?
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 05-31-2015, 09:23 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If you can, just post some pictures
I sure someone will be able to identify the parts you have.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-31-2015, 11:24 AM
Pictures of Cam
I decided to pull a head to take a look at the pistons so I have also attached a picture of the piston. Maybe someone can give me an idea of the compression ratio based on the picture.
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 11:42 AM
Heads
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 11:43 AM
Piston Pictures
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 11:44 AM
Those are 2.2 S Pistons as I recall visually
There is a casting number inside piston. It ll be 84 a letter and 2 numbers. Will tell you exactly. S is 84P84
That's an S cam with the S on the nose.
The K number will tell you exactly the head you have.
Bruce
Old 05-31-2015, 12:12 PM
So, basically I have a 2.2 S spec engine?
The engine is a 911/51
What is the compression ratio of a 2.2 S?
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 12:20 PM
9.8. Now if you install a 2.4 crank and trim the skirt of the piston you can have 10.3
Bruce
Old 05-31-2015, 12:28 PM
That's what I was told was done, a 2.2 stroked to a 2.4
Guess I should have mentioned that
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 12:35 PM
What is the best cam timing for this setup?
It was set at 5.52
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 02:00 PM
I found that normal S cams set at 5.25
Thanks for all of your help
Tom Feeney
1970 911 T
1973 911 T
Old 05-31-2015, 05:40 PM
