Cam and Head ID Help Needed
I am tearing down my 2.2 that came in a car that I got a few years back to put some new seals in it and I am interested in the parts that were used in it as it was built for a lightweight autocross car.
So, I pulled the right cam out to reseal the cam housing and the cam numbers are 901.5110.1R the end of the cam has an S and a single dot. The heads are part number 911.104.307.0R and are dated 6-70 I am told it has 10.1 compression but I don't know how to verify that as I am not pulling it down that far. Anything else I should look at to get a better understanding of what I have?
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Try not, Do or Do not
If you can, just post some pictures
I sure someone will be able to identify the parts you have.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Pictures of Cam
I decided to pull a head to take a look at the pistons so I have also attached a picture of the piston. Maybe someone can give me an idea of the compression ratio based on the picture.
Heads
Piston Pictures
Those are 2.2 S Pistons as I recall visually
There is a casting number inside piston. It ll be 84 a letter and 2 numbers. Will tell you exactly. S is 84P84 That's an S cam with the S on the nose. The K number will tell you exactly the head you have. Bruce Last edited by Flat6pac; 05-31-2015 at 12:14 PM.. |
So, basically I have a 2.2 S spec engine?
The engine is a 911/51 What is the compression ratio of a 2.2 S?
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 Last edited by Amstaff; 05-31-2015 at 12:29 PM.. |
9.8. Now if you install a 2.4 crank and trim the skirt of the piston you can have 10.3
Bruce |
That's what I was told was done, a 2.2 stroked to a 2.4
Guess I should have mentioned that
What is the best cam timing for this setup?
It was set at 5.52
I found that normal S cams set at 5.25
Thanks for all of your help
