Al S's Avatar
Pitted 2.2 Cylinder - Opinions
Rebuilding a '70 2.2, and found one of the cylinders pitted as shown.
These are Mahle jugs with the iron sleeves.
The pit is just below the compression ring at TDC.
One local engine builder opined that it should not be a problem.
Looking for opinions on what my options are (other than oversize JE pistons and rebore).
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 07-09-2015, 09:51 PM
porschetub's Avatar
I would be looking for a replacement barrel that up to spec still,IMO this pitting will cause blowby......sure the guru's will chime in on this ,good luck
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-10-2015, 02:00 AM
If I'm looking at the picture correctly, there looks to be a noticeable ridge at the top of the iron liner. If you can catch your fingernail on it, the ridges should be removed with a ridge reamer if the other cylinders also have ridges. I agree with porschetub, I wouldn't use this pitted cylinder.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 07-10-2015, 08:02 AM
Its not something I would ever use in any engine, as is.
Personally, I would look for a better cylinder that can be finish honed to suit, or bore the set oversize and fit some JE's.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-10-2015, 12:38 PM
Straight shooter
Lapkritis's Avatar
I've seen worse come from happily running engines.
Would it run and likely not be noticeable? Sure. Not going to find many builders who would give it a stamp of approval publicly though... It won't get any better that high in the cylinder where pressure is great.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-11-2015, 06:40 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If the pistons are still usable, I would suggest having all your existing cylinders Nikasil coated. The coating will repair any surface anomalies, can be sized to each piston and offers better sealing and reduced friction making the cylinder better than new.
If the pistons are not within spec, I would look to bore the cylinders and replace the piston with an over-sized one.
Since the engine is apart and the cylinder shows issues, why use it as is?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-11-2015, 10:55 AM
Al S's Avatar
Thanks for the feedback guys, particularly from our resident engine gurus Steve and Henry.
Much appreciated.
This is a budget rebuild so I will look at replacement with a used cylinder.
Al Shkuratoff
Old 07-12-2015, 01:34 PM
Much appreciated.
Talk to Ken at 911 Vintage parts 760-731-4911
info@911vintageparts.com They have a huge selection of used air-cooled Porsche parts.
Henry Schmidt
Ph: 760-728-3062
Old 07-12-2015, 03:01 PM
