Farrell's Avatar
911SC Engine Removal
Hi All
Its my first time removing the engine in my 1982 911SC, as I really need to replace the airbox due to a backfire. I know you don't HAVE to remove the engine, although i have a Oil Pressure switch leak i believe, coming from the triangle and i figure i may as well just pull the motor and clean up the whole triangle area.
Heres my list of things to replace at this time:
Oil Pressure switch
thermostat O-ring
Oil Breather Hoses
CIS intake manifold hoses
oil cooler seals
Adjust the valves or replace Cams with 964 or webcam 20/21
Replace pulley seal
Fix heater boxes
maybe a stater rebuild?
SSI
M&K Muffler
Wevo motor and trans mounts
Also, im thinking while I'm in there ill powder coat the valve covers and all the engine tin as well as the fan. Clean up the motor while I'm doing all this maintenance.
Did i miss anything?
Now my real question is, I was thinking of dropping the engine and the trans at the same time (3.0 with 915), is this easier than dropping just the motor?
I just picked up a set of 46mm PMOs, so i wanted to install those and a set of cams, i haven't found too many great write ups on replacing just the cams, i just know you need the special Porsche P202 tool and the 46mm crawfoot wrench. how difficult is it to time the cams? what cams do you guys recommend? Webcam 964 grind or a 20/21? I've heard they are relatively the same?
i have an USA 911SC so, i think i need to port the intake heads to 40mm from 38mm? i can't remember the exact number, but i was told it can be done with the engine on an engine stand flipped upside down. is that ludicrous or doable?
thanks for your help in advance!
Old 04-25-2015, 08:54 AM
Your probably going to find some broken head studs if the dilivar head studs havnt already been replaced. You might as well do the whole motor,clutch et,et,et,. Maybe enjoy the Michigan summer and wait till winter.
Old 04-25-2015, 09:03 AM
Farrell's Avatar
i was thinking that too, its not driveable with the cracked airbox at the moment, thats what needs immediate attention to get back on the road.
ill start with draining the oil and pulling the valve covers, but i bought the car 9 months ago and when i had the PPI i had no head stud issues. so, it should be the same still considering it hasn't been driven in 6 months due to winter.
Old 04-25-2015, 09:39 AM
Under the radar
Trackrash's Avatar
Do you have Wayne's "How to Rebuild and Modify Porsche 911 Engines"? If not, it is available on this site and a must read.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-25-2015, 11:54 AM
Farrell's Avatar
Ya, I've read it. I was curious if it was easier to remove engine and trans together or separate engine from trans? Is one or the other faster and or easier?
Cheers
Old 04-25-2015, 04:15 PM
Under the radar
Trackrash's Avatar
Much easier to remove together. IMO
You probably have the small port heads. I think that 46 PMOs may be a bit large, depending on what cam you plan on using.
With the stock pistons, you are limited in what cams you can use. Stock pistons also limit your engine's rev limit to near stock.
When porting the heads you need to match the manifolds.
You should talk to your cam grinder about your planned use for your motor.
Gordon
Old 04-25-2015, 05:37 PM
Farrell's Avatar
Got some progress done today. Rebuilt the heat exchangers, nobody will see these once their in the car, but it needed to be done.
Picked up some new ducting as well, as the old ducting was falling apart.
Painted part of the alternator housing as well.
Been cleaning everything, mostly the engine bay right now so, I can repaint it. Incredible how much grease builds up in the engine. Also, cleaning the glue from the sound pad sucks.
I was thinking of painting it black, original color is grand prix white. Gonna paint the car back to original color in a year or two, but not for concours reasons. Mostly cause I like white cars. So, white or black? Any recommendations on prep? Bring down to bare metal? Just Bristol pad?
Old 06-28-2015, 08:27 PM
It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Cam timing slowed me down on my rebuild (fear?) but once I got into it it was pretty straightforward.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 06-29-2015, 05:36 AM
Stripping engine bay down to bare metal is a huge PIA.
Old 06-29-2015, 04:35 PM
Power wash with a quality detergent is far better than trying to strip paint.
Bruce
Old 06-29-2015, 05:15 PM
Farrell's Avatar
Bruce
This is what I was thinking.
Would you guys replace the starter or alternator while your in there? Do they tend to fail often?
Old 07-02-2015, 09:11 AM
Farrell's Avatar
Also, since ill be running carbs now do I just plug my O2 sensor? Or do I continue to use it?
Old 07-02-2015, 09:15 AM
No need for 02 sensor if your running carbs
Old 07-02-2015, 10:28 AM
non-whiner
mreid's Avatar
The alternator and starter are both fairly easy to replace withe engine in the car. I say leave them unless you have an extra $1,000 hanging around.
"Too much is just enough."
Old 07-02-2015, 10:47 AM
Farrell,
Another suggestion for 'while you are in there' is to replace the fuel lines in the tunnel. I have not replaced mine yet, but I have heard it is a PIA.
Can't remember the person's name on this board that makes great replacement lines that are compatible with today's gas, but someone else will chime in with it.
Craig
77 Ice Green 911s w/3.0
Old 07-02-2015, 12:13 PM
Farrell's Avatar
Originally Posted by Craig View Post
Farrell,
Craig
Nice suggestion, do these go bad since they're metal lines? I know Gordo did a sweet setup with AN lines.
AN-6 Fuel Line Plan for CIS to PMO Carb Conversion
Good to hear that the alternator and starter can wait. It was in my cart and around $700 so I wasn't looking forward to that.
Happy 4th all!
Old 07-02-2015, 01:31 PM
Farrell,
Here is a link to the fuel lines I was talking about. You may not have these 'problem lines'. This thread explains things pretty well.
Fuel Hoses - 911SC Tunnel to Motor
HTH,
craig
Old 07-02-2015, 02:21 PM
Farrell's Avatar
So while I wait for my engine harness to come back from Dennis (Timmy2, insane turn around time!) I stripped the engine bay in anticipation if re painting this.
It's hard to tell, but this whole trunk was black with grease and crappy spray paint.
Now I have read that many people were just having their paint color mixed up, add some thinner to it and then roll it on with a foam brush. With the thinner applied they said it should smooth out and look real nice. Anyone else do this?
Paint in this order?
Epoxy primer on bare metal
Body filler or undercoating for texture
Paint
Clear
Old 07-04-2015, 11:19 AM
I would use a single stage paint.
Old 07-04-2015, 01:10 PM
non-whiner
mreid's Avatar
And use a Preval sprayer. It is perfect for this application and will look great.
Old 07-04-2015, 02:36 PM
