Cam shaft securing bar - 3 choices - much difference???
Just getting ready to order a camshaft securing bar for engine rebuild - 88 911. I see there are three choices offered from our host......is there really much of a difference between them apart from price point.
Porche OEM part 000-721-919-10 OEM $170
Cam Holding tool part 000-721-919-10 $120
Cam shaft securing bar part PEL TOL P237 $80
Old 07-27-2015, 11:54 AM
I found out our host sometimes uses different vendor for the same product and prices differ.
Example:$170 is Porsche, $120 OEM provider, $80 same as $120 just cheaper.
Call and ask them
Old 07-27-2015, 01:24 PM
VW_NUTT's Avatar
Are you wanting this tool just to remove the bolt that holds the cam gear on? Use an impact and socket. Its not on that tight.
1984 Carrera
1985 Vanagon Westfalia
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 08-01-2015, 08:22 PM
non-whiner
mreid's Avatar
Off is easy, back on more challenging. Go with the cheap one unless you plan on many rebuilds.
"Too much is just enough."
Old 08-02-2015, 06:35 AM
gtc gtc is offline
abides.
gtc's Avatar
The cheap one (SIR Tools brand) is plenty nice.
QSC makes a chinese knockoff also, which you can find for a bit less elsewhere (google).
Graham
1984 Carrera Targa
Old 08-03-2015, 11:10 AM
