LinkBack | Thread Tools | Rate Thread |
Max moritz 3.4L 9.8:1 comp ratio pistons - what is the piston top volume and height?
Max moritz (3.2 to) 3.4L 9.8:1 comp ratio pistons - what is the piston top volume and or height?
Mahle reports 35.4cc/10mm and 28.3cc/9.3mm, but i do not know which is the 3.0 to 3.2L vs 3.2 to 3.4L. See post #9 below for where I got my info. Edit: As Per Mahle Motorsport, the answer is 35.4cc for the 3.4l pistons! i would measure mine, but they are installed, and i figured it would be easier to find out online than it is. Will check with mahle monday, but i figured i would try. Thanks for any help. John Edit: or... What are the specs for the 3.0 to 3.2l pistons.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 08-04-2015 at 06:43 PM.. |
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Under the radar
You need to measure it yourself to be certain. Look at post #26 here.3.1 Short Stroke Build 66 X 100
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Under the radar
Not if you haven't installed the cams....
If the info is not available via the brain trust of the internet, i will await the answer from mahle, and then post back here.
Under the radar
There are a number of variables that can affect a compression ratio. If you really want to know your CR, you should do the check.
But you are right.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 08-02-2015 at 07:16 AM.. |
Here is where I got some of my info that raised my question of the true dome volume for these pistons. Sadly, EBS, who supplied my pistons, had no more in stock to give me measurements, and his Mahle rep was gone for the weekend. They wil be getting back to me early next week. I also emailed Mahle, to see what they say.
Here is a supposed word for word response from an email inquiry to Mahle. Mind you, I have posed questions to Bilstein about shocks and got a rep who gave me bad info. After calling them on it an re-inquiring, I got the correct info. Numbers are only as good as the data given. Quote:
Interestingly, my forging number seems a bit different. Presumably just a different production run. ![]()
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 08-02-2015 at 07:33 AM.. |
FYI:
This piston is from the set that was used in my 3.2 to 3.4 conversion. It is listed as 9.8 CR, with my final CR measured at 10.0 due to head work. ![]() Peter
Peter 1987 Carrera Coupe 3.4 2003 Boxster S (SOLD) 1986 Carrera Coupe - (SOLD) 1984 944 - (SOLD) |
Here's pictures of my 98mm 3.0 to 3.2 pistons. If you look at the short side of the dome, it's clear that it is shorter than the short side of the 3.2 to 3.4 pistons you have. That's a pretty good indication the 3.4 pistons are the ones with the greater dome volume and higher compression.
![]() ![]() My best guess would be that the 3.4 had the higher 9.8:1 ratio due to the Motronic having spark control in it's mapping and could handle the higher comp ratio. The lower 9.3:1 3.0 to 3.2 where originally developed for the low compression (8.5:1) big port Euro spec engines that didn't have spark control, but had a richer tuned CIS. It could only handle a modest increase in comp ratio without spark control when ran on premium fuel and an adjustment of the CIS to run a bit richer. That's my guess anyway. I'll be curious what info you get from Mahle.
JoshD, thanks for those photos!!! You basically answered my question then. Makes sense, and it means my comp ratio should be near bang on! I will await word from mahle before anouncing it to the world.
Thanks again!
I'm still not convinced of the 28.3 cc dome volume of the 3.2l 98mm piston. That's essentially the same dome volume and comp ratio as the stock 8.5:1 95mm piston. Everything I've read or seen advertised says 9.3:1 or 9.8:1.
What makes me scratch my head is that billb123 measured 9.3mm for the height of his 3.4L piston tops. Makes me wonder about the accuracy of the info that supposedly came from mahle. Again, I was given bad info from Bilstein once. Mahle does produce a million different pistons.
My attempts to get info from Mahle have been stalled as the only part number I had was the one from the top of the piston, which they reject, resulting in them telling me they can not answer my question (via email). Hopefully Don from EBS has better luck with his Mahle rep.
So here is the response from Mahle. They gave me the run around at first, saying i needed to give them a parts number... Which i did, each time. Here is their response:
"Called Motorsports for you this morning & confirmed part # & specifications for you. Compression height is 32.8mm. & volume is 35.4cc & this is based on the 3.2 to 3.4 application. The actual part # is PP98-013" So my compression ratio is spot on!!
What is the piston pin diameter for the 3.0 to 3.2 conversion set?
No idea. Sorry
22mm
