DIY Cleaning Soluion Recipe for Parts Washer
Got a good recipe for a DIY el cheapo parts washing solution?
I've been using a 50/50 mix of diesel and "odourless" mineral spirits. I can't find kerosene anywhere near me, but I guess diesel is close enough.
It cleans the parts pretty good, but it stinks up the house (which I can live with) and it also leaves the tiniest bit of an oily residue.
FWIW I am using a $100 Harbor Freight parts washer which, although it says water based solutions only, is working great.
I find that pairing this solution with a well-hopped IPA works best. Dogfish Head 90 or Sierra Nevada Hopsecutioner.
I will probably give everything a final spray in Coleman Fuel if I can find anyone that carries that any more.
Old 08-25-2015, 06:15 PM
Chain fence eating turbo
Naphtha
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-25-2015, 06:35 PM
Try ACE Hardware for the Coleman fuel
87 Carrera Venetian Blue gone but not forgotten.
Old 08-25-2015, 08:44 PM
The latest addition to my parts washer just arrived today: a filter for an oil fired boiler. It's designed to filter diesel fuel and its filter elements are cheap. I'm going to plumb it in the pump outlet.
For the solvent I'm using high flash point Cleaning solvent from Tractor Supply.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 08-25-2015, 09:07 PM
Project Addicted
Ultrasonic cleaner. Uses water and Dawn detergent. No fuss, no muss, no bad smells.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 08-27-2015, 07:41 PM
How well does it work with coke and other baked on deposits?
Old 08-28-2015, 01:31 PM
Project Addicted
Check this thread.
Excellent Part Cleaner
It won't remove the hardened stuff on a piston top. But it cuts thru most other stuff. I have had to do only 2-3 parts 2 times thru.
Jon
1966 912
1986 944
Old 08-28-2015, 01:39 PM
