Are These Ring Considered Seated, or Not Seated?
This is Piston #1, 900 miles since rebuild.
Do the experts consider these rings worn in enough to be considered seated? Or, due to the limited edge polishing, consider these unseated? Is this what unseated rings look like? http://forums.pelicanparts.com/uploa...1440857543.jpg Background: Rebuilt engine in May, followed break in procedure. Start with SAE30 and new filter, after 20 minutes drained (& new filter) and filled with VR1 20W-50 Oil for 38 miles, change + filter, ~850 miles on VR120W-50. Still burning ~1qt/350 miles. I have run this engine quite aggressively to try and seat the rings, but it has not seemed to work. When I pulled off the carbs, I found a lot of oil in the intake runners. I though it was the heads, so off they went. Turns out there was nothing wrong with them. So that leaves the rings. BTW, the rings did migrate. both upper rings ended up on the same side, and the oil ring rotated 90 to the other side. Can't stop rings from moving. This is what they looked like when I installed the rings. http://forums.pelicanparts.com/uploa...1440858638.jpg |
I once tore down my hotrodded VW motor because of oil in the cylinders. I thought it had a broken ring. Turned out to be the same thing as in your motor, the oil ring turned to have it's gap at the bottom.
I would be interested in hearing what the experts have to say about this as well. |
Did you check the actual gaps in the rings by setting the rings only in the cylinders before installing on the Pistons?
Yes. Ring gaps were individually set based on factory specification. And all rings were set as shown in my top shot picture.
Leakdowns?????
Mid-20s
Trying to figure out if it is a problem or just that the rings still need to broken in. after 900 miles I would have thought I was close.
New cylinders?
Millenium technologies, Nikasil plated, Alusil cylinders. Goetze rings, JE pistons
I have heard, Goetze rings are a ***** to get seated!
It's always been my experience that the rings will move to where they want to go.
Bruce |
The two rings you point out at the top are tapered. Those are the compression rings and that is why they are shiny at the lower edge. The two rings at the bottom are the oil rings. That is why they are flat against the cylinder wall.
You can do research on engine ring construction and design to give you way more info then I have to offer. |
One other thing, did you check the gap between the ends of the rings when compressed. If you squeeze the ring to where it bottoms out on the piston there should only be minimal gap according to the specs of your particular vehicle.
That also help keep the rings from rotating. As you well know when the piston is cold the gap will be larger. When both the piston and ring expands the gap is almost closed. That may be the reason for burning oil prematurely your gap may be too wide. |
Another thin with regard to ring installation the gap on those rings need to be set so they are a quarter distance from each ring.
Example first gap 12:00 second ring second gap 3:00 position, third ring third gap 6:00 position and fourth ring 9:00 position. Doing that keeps the oil from migrating through with regard to the oil rings, and it improves compression with regard to the compression rings. |
FWIW,.....I've had trouble seating Goetze rings with Millenium's nikasil-type plating; its different from US Chrome's process. You may need to use a domestically made ring package after deglazing the cylinder walls. |
Steve, cgarr
Thanks for your thoughts on Goetze rings. And related to the plating. How should I deglaze the cylinders? Hone or just scotchbrite? Any options on sources of rings? Goetze seem to be the standard. |
Ok. I searched the forum. Quite a few options on deglaze. Seems red scotchbrite is the preferred method.
911 ring gap positions
From the factory manual if it's any help.
http://forums.pelicanparts.com/uploa...1440945839.jpg |
4 - 10 - 2
Interesting spacing recommendation. |
Its VERY VERY critical that you wash the cylinder bores VERY thoroughly with hot soapy water until a white cloth wipes clean through the bores. I use cloth baby diapers moistened with either light oil or WD40 which lets me know when things are clean. Failure to do this properly leaves very fine particles of carborundum in the bores which will rapidly wear the rings. |
Thanks Steve. Just did number 1. Red scotchbrite.
I noticed how good a little bit of oil picked up the dark residue. A good cleaning is next. I figure I will reuse the existing Goetze rings. They are part of the way to seated. Just clean and reset position. Then pull the remaining 5 p&c and do them. |
Obviously hard/chrome rings and hard cylinders are going to take awhile to seat. I think over oiling the pistons/rings/cylinders on assembly can be problematic too. A local engine builder recommended a light coat of WD40 only. It worked for me.
I'm wondering what other rings besides Goetze or OEM are used? I see the Goetze at $22 and the OEMs at 6x that:eek: Perfect Circle is now Mahle so I'm assuming the OEMs are Mahle/Perfect Circle? I see Hastings makes them, Total Seal shows a conventional set for the 3.0L only. Federal Mogul owns the Goetze and also Sealed Power brand I'm pretty sure.
Has anybody tried this magic "snake oil" powder? Quick Seat Piston Ring Assembly Lubricant, by Total Seal, 2 - Aircooled.Net VW PartsGrams
You don't need "snake oil" powder if you do the ring assembly and installation correctly. Several factors can have an effect on the final outcome if not done according to specs and procedures when it comes to doing a rebuild.
It seems doing it the right way doesn't always equal success. Followed all the proper procedures. Ring gaps, piston clearance. Side clearance. Cleaning. Refurbished cylinders. New pistons and rings. Lightly oiled to get piston and rings into the cylinder. Then wipe down the walls to remove excess. Followed the break in routine. Acceleration and engine breaking. And the rings did not seat after. 900 miles.
So engine teardown and rebuild number 2. And no guarantee the rings will seat. So why is this not a problem for all modern engines? Subject of a new thread. |
I wasn't indicating you didn't do the job right. However I think your problem is with the rings rotating on the piston.
This probably caused more oil to pass by the oil rings and cause the compression rings to be wetter then normal resulting in the rings not being able to seat properly. It also caused excessive use of oil. Make sure your cylinders are cross hatch honed and there are no shiny spots on them. If the rings are gapped properly and the gaps are staggered per the picture, I don't think you will have anymore problems. I remember when I did my ring replacement my compression was non existence when I first tried to start the engine. But after several tries, it fired right up. If everything goes well, your rings should seat within 500 miles. I think the excessive oil bypassing the oil rings wouldn't let the rings seat properly. |
No I wasn't taking offense. I appreciate you being concerned if I did.
I was venting a little. Just checked pistons 2 & 3. Both had rings completely rotated out of position. Yes that is my goal is to removed any of the existing shiny spots by lightly scuffing the walls. |
Steve.
Couldn't we just sneak a peak behind the curtain? :) |
Did you assemble the rings with oil or dry?
I wiped the cylinder with a light coat of oil using a kimiwipe. Then wetted the outer edge of the rings to insure they'd slide on the ring compressor. Very little oil overall. No puddles. No thick layer.
Wiped off oil with a fresh kimiwipe. Surface was not bone dry; nothing more than a sheen. That seemed like I followed Wayne's instructions. |
Do you really think that you will find any of your pistons with the rings in the exact orientation as when you assembled them? This is an impossibility as the rings will rotate within the bore due to the cross hatch. Once they are seated they will stop rotating as much, but you can't stop the rings from rotating during break in. |
My company had a large fleet and this process was adopted from then on every rebuild ....problem of slow bedding of rings fixed,in fact one of our vessels was reringed twice in the past and this sorted it for ever from then on. IMO don't use those rings again,if you rehone they will give issues. |
Interesting idea of the kerosene. Flashes off and allows ring to cut.
I am only deglazing by a light scrub with a scotchbrite. Original cross hatch is still there. So I that regard I should not expect much more wear to get seated. They aren't even fully worn on the edge. Just the lower edges. |
Staggering the ring gaps upon installation is good practice. But once the engine is spun, all bets are off where the gaps will end up. Some of the comments here about the gap orientation imply that we're talking about very large gaps which allow massive amounts of oil to squeeze thru the gap. The ring gaps are not the issue here, as they are very small. It's the interface of the rings with the cylinder walls.
KTL is spot on.
Because the rings never seated they do not have a proper seat to the cylinder walls and therefore do not wipe the excess oil from the walls and are allowing oil into the combustion chamber. This is contaminating the mixture and also burning the oil with the combustion process therefore your excessive oil consumption. If you are going to re use your original rings then I would clean the cylinders as Steve has stated and then install with either Kerosene or dry then carry out the high rev back down break in. Let us know what the out come is. Good luck. |
Should I replace the rings?
I am deglazing the cylinder walls as Steve suggested. But is the current ring wear pattern a big problem? only the lower edge is polished, is that bad? Based on the picture attached. Will my current rings work? |
