BTR motor rebuild
I have a 1981 BTR that needs a complete motor- I might as well, as there is no compression in two of 6
My question is who to trust with this motor. I have RUF paper work it was put together in Germany by RUF as well as a 5 speed hook up.. I wantit done to specs to preserve the car. So thoughts gentleman? thank for your help Doc |
I guess that depends if you want it done locally or you want to ship the motor somewhere else. There's a lot of people that can do a good job rebuilding it.
Perfect Power in Buffalo Grove, IL used to be a Ruf dealer and I know he has built a few BTRs.
Kartoffelkopf
Chris @ TurboKraft
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Steve W@ Rennsport Systems
thanks all
Constitutional Liberal
Supertec Performance
Henry Schmidt 760-728-3062 supertec1@earthlink.net They built both of my 930 engines. 3.1 has 15 years of use and 3.5 has 11 years. Zero issues. I just wish they would work on water-cooled as well.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Not to take anything away from any builder mentioned in this thread but last I knew the NA Ruf distributor was in Southfield... Probably worth a phone call given your proximity.
'90C4 |
Done several BTRs and BTR-IIs.
Here's one we did in 2013. The owner already had a carbon fiber fan shroud and had painted his fan red, wanted to keep both, so we refreshed them while remanufacturing everything else to as-new condition. (Yes, 1-3 air duct missing, we were waiting on one from Germany.) Even remanufactured the unique "Grosse K27" -- no, those are not the same as the old K29/27 hybrid turbos everyone built. ![]() ![]() ![]()
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Done a twin turbo ruf right here in Kalamazoo not to far from you car was later sold at gr auto gallery
Claudio |
gearhead
I wouldn't put much stock in who was a Ruf distributor. Some of the operations they have licensed over the years haven't been the best. You want to pick a good engine builder. It doesn't matter much whether they have a Ruf history or not. There's some good ones here.
For an engine I like to work with someone local so I can manage the job. Too many long distance blackhole stories around here. I'd probably call Claudio first and talk to him about it.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
