Alex973's Avatar
kevlar
have anyone here used Kevlar oil lines instead of
braided SS lines? how good are they and who sells
oil line with the right fittings (AN) thanks I appreciate your
response, my oil lines are brass gone through hell
"IGNITION LEFT OF STEERING"
Alex
Old 10-10-2015, 06:45 PM
304065's Avatar
Aeroquip Startlite. You buy the fittings from an Aeroquip dealer and put them on yourself according to the manufacturer's instructions. Or you can use Earls, etc. These days no serious race team uses the braided stainless, it's too heavy, difficult to fabricate and the cut ends will do a number on your skin. Even NASCAR has moved away from Aeroquip, they use ICORE, Goodridge, etc. at like $40 per foot.
I once bought used NASCAR lines for a significant discount and ran a patch through to verify they didn't contain chunks of bearing, this worked great. (I never found any metal.) You can usually find them with end fittings already swaged on.
I cannot say I would use them, or any flexible line for that matter, on the outside of the car. The brass Porsche lines act like a radiator themselves and have proven to be able to stand up to road hazards. So if your brass lines look like a trombone from the battle of Waterloo, you will find it cheaper and easier to stay with the factory approach... or even better the finned ones from Elephant Racing.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-11-2015, 04:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
anplumbing.com is Earl's Store #1 (that's how they answer the phone, literally) and they sell the kevlar stuff.
AN Ultra-Flex Hose | ANplumbing.com
Note that this hose requires crimped hose ends and therefore it's typically not something you can DIY assemble. T
Kevin L
'86 Carrera "Larry"
Old 10-13-2015, 02:14 PM
