xjoegtix's Avatar
Rocker arm adjustment screw?
Hey guys while testing my valve to Piston clearance I unscrewed the nut a bit and noticed the threads on the bolt were coming off. I looked at the others and they're all fine.
I just need the one. Was wondering if I could buy that?
The rocker is fine just were the nut would sit isn't in good shape.
Alsooooo
Do I have to pull the rocker off to replace that?
If I do need to pull it off do I need to take the cam chain housings off to get the rocker shaft out?
Old 10-24-2015, 03:46 PM
non-whiner
mreid's Avatar
Our host sells them. You do have to take the rocker out. Two Allen keys will work, but sometimes getting the rocker pivot out can be a pain when the others are in place. Good luck!
"Too much is just enough."
Old 10-24-2015, 03:49 PM
xjoegtix's Avatar
Thanks mreid!
Old 10-24-2015, 04:07 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I'll send you one if you can't find one. You don't need to pull off the cam chain housing, the pin will come out without removing anything else. I use a brass 1/4 dia rod to tap out the pin after the lock screw is loose. Be careful not to ding the aluminum bore.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 10-24-2015, 04:20 PM
xjoegtix's Avatar
Porsche84 I couldn't find one on pelican. What would you want for it. My car is a 3.0 SC
Old 10-24-2015, 05:37 PM
Porsche84's Avatar
PM your address I'll send you one for free.
Jerry Austin
Old 10-24-2015, 07:04 PM
xjoegtix's Avatar
Pmed thank you!
Old 10-25-2015, 10:25 AM
Hey Joe
I can throw one in with the piece of engine tin you purchased. I just need your mailing address.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-26-2015, 04:08 AM
Porsche84's Avatar
I'll hold off sending one, take Tom's offer
Jerry Austin
Old 10-26-2015, 04:53 AM
I think you can change it without removing the rocker arm. In fact you might have trouble screwing the adjuster bolt through the arm since the thrads are so buggered up. You just unscrew the adjuster and the foot will pop off. Re-install the same way.
-Andy
Old 10-26-2015, 04:29 PM
xjoegtix's Avatar
Tom1394racing thank you so much for sending me that! It's perfect
Old 10-28-2015, 02:40 PM
