Counterclockwise?
Please show me your engine drop stand
Hey Gents,
Getting ready for my engine drop.
When using a lift, what is everyone using to drop their engine on?
I was thinking of using a engine cradle with plywood on top.
Rod
1986 Carrera
2001 996TT
Old 11-02-2015, 07:46 AM
I just use a furniture dolly. Under $10 at Home Depot or Harbor Freight.
Old 11-02-2015, 07:55 AM
Counterclockwise?
Seeing that I have a lift, I was hoping to work a bit higher than that.
Rod
1986 Carrera
2001 996TT
Old 11-02-2015, 08:20 AM
Other options are motorcycle lifts and lift tables. HF has lift tables that support 500 or 1,000 pounds depending on the model. HF is ok for occasional use in this case.
Old 11-02-2015, 08:42 AM
I am my 911's PO
'78 SC's Avatar
You're right about wanting to work higher. I used an ATV jack with my MaxJax and had to keep the lift low. Negated some of the advantages.
I bought the HF 1000# table for my next engine drop. I plan to work out a mechanism to control angle to get the transmission in and out. More importantly a positive lock to hold the table up. That thing is one hydraulic leak from being a guillotine.
Old 11-02-2015, 10:17 AM
Counterclockwise?
I was thinking one of these with a platform on top.
Rod
1986 Carrera
2001 996TT
Old 11-02-2015, 12:45 PM
HF lift table. Works well. Can also transfer the engine to stand instead of using a cherry picker.
1000 lbs. Capacity Hydraulic Table Cart
Old 11-02-2015, 06:55 PM
It looks to me as though the engine cradle is using a V8 engine block for some of its structural integrity. It's probably plenty strong for the P engine weight, but I would weld a couple of extra cross members to keep the members from spreading apart when it is loaded.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 11-02-2015, 07:36 PM
Counterclockwise?
For sure. I was going to run angle iron to join the posts. The beauty of this one is you can slide a jack into it if need be. Plus it's $40!
Rod
1986 Carrera
2001 996TT
Old 11-03-2015, 06:14 AM
toddu's Avatar
Bought one of these with the 20% discount. Works perfectly with my midrise lift. It's very heavy and stable.
Todd
'81 SC
Old 11-04-2015, 04:26 AM
bgyglfr's Avatar
I have a four post lift. I just use some heavy saw horses and 2x4s. Then I use the lift to raise it off them for the engine stand.
70T 2.7RS spec.
68L coupe
Old 11-04-2015, 05:52 AM
Alexm930's Avatar
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 11-06-2015, 06:04 AM
Counterclockwise?
^^^Nice
Rod
1986 Carrera
2001 996TT
Old 11-06-2015, 06:14 AM
