How to compress chain tensioner to install
I'm trying to replace a chain tensioner, I compress the piston slowly with C clamp, but as soon as I remove piston pops up immediately.
How do I get it to stay so I can slide it in |
You need the little pin that holds it in place. I made mine from 1/16 music wire. Coat hanger wire would be ok.
There is a hole the wire goes into. Piston has to be in almost the entire way. New tensioners come with the pistons retracted and a nicer pin |
Cotter pin or finishing nail will also work.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Functionista
Or Allen wrench
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
I used an Allen wrench as well.
Mike '89 CARRERA #402 |
