How to compress chain tensioner to install
I'm trying to replace a chain tensioner, I compress the piston slowly with C clamp, but as soon as I remove piston pops up immediately.
How do I get it to stay so I can slide it in
Old 11-27-2015, 08:03 AM
VFR750's Avatar
You need the little pin that holds it in place. I made mine from 1/16 music wire. Coat hanger wire would be ok.
There is a hole the wire goes into. Piston has to be in almost the entire way.
New tensioners come with the pistons retracted and a nicer pin
Old 11-27-2015, 09:56 AM
Jeff Alton's Avatar
Cotter pin or finishing nail will also work.
Cheers
www.turn3autosport.com
Old 11-27-2015, 08:26 PM
Functionista
manbridge 74's Avatar
Or Allen wrench
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 11-27-2015, 09:18 PM
michael lang's Avatar
I used an Allen wrench as well.
Mike
'89 CARRERA
#402
Old 11-28-2015, 12:36 AM
