totle's Avatar
Drill hole for oil squirters
Hi,
I have a 2.2T with S-spec and Nikasil cylinders.
Want to install oil squirters and do the oil-bypass
I found a picture with an illustration of how the oil is routed.
Is it just to drill a hole down do the passage for the bearing oil channel?
I have a machine shop guy doing VW engines, so would like for a procedure of how to drill the holes for the squirters.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-03-2015, 03:44 AM
In my opinion use a machine shop that has done this before. It's not as easy as it looks. I did it locally once maybe 25 years ago and the squirters kept coming loose. I'm not going to recommend a machine shop to do it because there are many of them out there. My $.02 worth.
Old 12-03-2015, 06:42 AM
totle's Avatar
Thanks, but this is a great shop.
Just not did this before.
Trond R.
1986 944 Turbo
Old 12-03-2015, 07:16 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Ask cgarr here on the forums. He does all sorts of case machine work and can tell you how he retrofits squirters into older cases.
Kevin L
'86 Carrera "Larry"
Old 12-04-2015, 09:15 AM
