Spark plugs after a complete rebuild
Evening all...
After a complete rebuild and new P/C with rings...I was doing my 500 mile break-in service and I was looking at my plugs and noticed that 6, 5, & 4 had a fair amount of carbon build up versus 1, 2, 3 which were fine.
My car ran a bit rich until I could tune the Air fuel which it did take multiple times with varying weather temps and finding out I had a bad fuel relay.
I cleaned them up and I should have taken a photo.
I am using Bosch W4CS and set at .07m
Why one side
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 12-04-2015, 03:25 PM
Straight shooter
Lapkritis's Avatar
Carbs out of balance? Check adjustment to make sure the butterflies open simultaneously.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-04-2015, 09:00 PM
No Carbs...
Anyone??
Scott
Old 12-05-2015, 04:53 AM
Chain fence eating turbo
Originally Posted by vascott01 View Post
No Carbs...
Anyone??
You still haven't mentioned what engine, induction system, nor ignition, and you're asking for help? :/
Old 12-05-2015, 06:12 AM
My apologies
1979 930 - engine 83 ROW/Canada based on the stamp on the case,
type 930/66
CIS fuel injection
Only Mod was 930 sport grind on the cams by Elgin Cams
Scott
Old 12-05-2015, 06:51 AM
plug wires?
Old 12-05-2015, 09:40 AM
The car drives well.. I might consider new wires. They were one of the few things I did not replace...
Scott
Old 12-05-2015, 12:17 PM
You sure that your plugs are set at .07mm gap? That seems extremely tight, like almost closed. 7mm might be better.
Gary Kozun
83 911SC Cabriolet
Old 12-05-2015, 12:34 PM
my mistake...bad eyes..it is actual .7milimeters based on my cheap gap tool.
Scott
Old 12-05-2015, 01:03 PM
Well then your eyes must bee really bad as the gap should be 7mm or 27 thousands of an inch.
I usually gap the plugs at 30 to 32 thousands for n/a but if your a turbo then 27 thousands or 7 mm would be right.
Gary Kozun
83 911SC Cabriolet
Old 12-05-2015, 01:09 PM
My apologies
type 930/66
CIS fuel injection
Try the 930/Supercgarging forum, lots of knowledgeable 930/CIS guys there.
79 is super special!
Old 12-05-2015, 01:12 PM
Plug wires for sure if you never replaced them; they really suffer on a Turbo.
If you didn't send the injectors out for checking and cleaning, thats what you do right now.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-05-2015, 03:00 PM
Back to school with you
1mm = ~.40", so 7mm would be ~.28" or over a quarter inch.
'90C4
Old 12-06-2015, 06:16 AM
crg53's Avatar
No offence, but your math must be really bad. 7 mm = 0.275591 inch, not 0.027 inch.
Old 12-06-2015, 06:19 AM
non-whiner
mreid's Avatar
Another possibility is cam timing on that bank. How does the engine run?
"Too much is just enough."
Old 12-06-2015, 06:26 AM
You are correct my math was terrible. Back to school for me and detention already.
.7mm should be the correct gap. Sorry.
Gary Kozun
83 911SC Cabriolet
Old 12-06-2015, 11:33 AM
I used Stromski's cam timing tool and had a buddy asist to ensure the second set of eyes. Unless it is now off by a micro hair. I am not sure...
engine runs great when it is warmed up. I am having an issue with the AAR. 1700 rpms on start up and after about 10 mins it drops down to 1250. Then after driving it for awhile it drops to 1000rpms.
Which I did remove and then added back as it seemed to work better after cleaning it up and checking connections. I do have a buddies that I will put in to see if that is causing the issue for the next 500 miles...
Thanks again all for your recommendations..
Cheers
Scott
Old 12-07-2015, 02:51 PM
