robmog's Avatar
cam change question.
how long would/should it take to change cams?
anyone got a link or list of the steps?
I have waynes book and could probably figure it out, after rebuilding my 2.4 E engine.
but it never hurts to ask first.
thanks.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 12-26-2015, 05:47 PM
non-whiner
mreid's Avatar
It a one day job if you have all the tools, know how to use them and know you won't have any valve train clearance issues.
"Too much is just enough."
Old 12-26-2015, 07:54 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I remember back in the day, changing the cams in an early 911 without even removing the engine.
We put the car up on jack stands, disconnected the shift linkage and lowered the back of the engine on a floor jack.
Pulled the muffler, rear engine tin, the engine cradle, valve covers and chain box covers.
All told it took 2 guys about 3 hours and a case of beer, IMSM.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-27-2015, 06:02 AM
Chain fence eating turbo
I assume the rockers were not changed out?
Old 12-27-2015, 08:14 AM
I'm not sure why you would assume that, all rockers were removed?
The reason they weren't replaced is that up until recently (last 8-10 years) rockers were never an issue.
The only time a rocker was replaced was when a oil tube got clogged and the rocker/cam lobe would eat each other or when welded cams were used.
Rockers broke during over-rev but rarely failed do to wear.
Major rocker failure is an entirely new phenomenon. I assume the issue is oil quality more than materials used.
We would occasionally see a void (pit) in a rocker pad starting in the early 80s but that was pretty rare as well.
Henry Schmidt
Ph: 760-728-3062
Old 12-27-2015, 08:28 AM
So the older rockers were no problem to run a new cam without resurfacing?
Old 12-27-2015, 08:55 AM
robmog's Avatar
I have a cam tower oil leak and figure to fix that I have to remove the timing chains.
So while I'm at it, I might want to install a sportier cam.
Old 12-27-2015, 09:38 AM
New, reground and used factory cams.
Henry Schmidt
Ph: 760-728-3062
Old 12-27-2015, 10:52 AM
Cams are the number one factor in determining the character of your engine. If you want to change the character, cams are the best way.
Henry Schmidt
Ph: 760-728-3062
Old 12-27-2015, 10:54 AM
Ok, thanks.
Many here recommended to resurface the rockers so the wear pattern of the old rocker wouldn't transfer to the new cam - hence original question as changing out the rockers with the engine in would be pretty tough.
Old 12-27-2015, 11:53 AM
Ok, thanks.
Prior to the oil deficiencies of the past decade and 1/2, cam wear was of minimal concern.
As for changing the rockers in the car, it is doable as my story indicates. You can't change cams without removing the rockers.
Henry Schmidt
Ph: 760-728-3062
Old 12-27-2015, 03:01 PM
Ah, I thought you could pull the cams without rocker removal with a little patience and rotating the cam lobes back forth.
That's silly quick in 3 hours then!!
Old 12-27-2015, 03:39 PM
I thought too.......
Tippy,
I was pulling out the cam and left the intake and exhaust rockers for cylinder #3. Expecting that by rotating the cam, I could wiggle the cam out. But I failed to get the cam to slide out after several minutes of trial and error. I still could not figure out why up today. So by removing all the rockers, not only it is convenient to remove and install the cam/s, you save a lot of time and frustration from trying to get the cam out with rockers installed.
Tony
Old 12-27-2015, 04:53 PM
Right on. Thought I was able to slide a cam out in my 3.2 during rebuild, but I guess not.
Old 12-27-2015, 05:44 PM
The issue is the diameter of the bearing journals, rotating them makes no difference.
Henry Schmidt
Ph: 760-728-3062
Old 12-27-2015, 05:58 PM
With the tools required and to dial a new cam in correctly,the engine would be on a stand in my shop.
New rockers too. That way there isnt a oil leak in sight. Slippery slope but new chains would be good too,not a fan of the chains with the joiner in... seen that little clip stuck to a magnetic plug once before... Game over,insert more money..
Old 12-28-2015, 05:30 AM
