Which lube for valves guides?
I'm rebuilding my heads. Which lube is recommended for the valve when installing it into the guide?
I was thinking the moly assembly lube used for the crankshaft and rod journals would be ok. Just not sure if the hot, sliding environment would need something different. |
abit off center
I do a 50/50 mix of torco assembly lube and motor oil
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
