VFR750's Avatar
Which lube for valves guides?
I'm rebuilding my heads. Which lube is recommended for the valve when installing it into the guide?
I was thinking the moly assembly lube used for the crankshaft and rod journals would be ok.
Just not sure if the hot, sliding environment would need something different.
Old 12-28-2015, 07:25 AM
abit off center
cgarr's Avatar
I do a 50/50 mix of torco assembly lube and motor oil
______________________
Craig
G2Performance
Old 12-28-2015, 07:34 AM
