My friends call me Phish
Weber Engine Cut Off
I started to experience an issue with cold starting. When the engine turns over it starts up and idles fine, but once I give it gas the engine will die. Any ideas?
Old 12-29-2015, 09:13 AM
Check your fuel pressure, float levels and accelerator pump volumes.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-29-2015, 10:42 AM
SoyRacer's Avatar
Simple - Sell them and buy a set of PMOs ����
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 12-29-2015, 05:13 PM
fuel pressure is at 5psi. If I am going to check the float levels and Acc pump shouldn't I just rebuild/clean them, since they have to be removed?
Old 12-30-2015, 12:28 PM
Walt Fricke's Avatar
Isn't the fuel pressure spec for Webers 3.5 psi?
Old 12-31-2015, 11:05 PM
FAR too high; fuel pressure MUST be 3.5 psi for Webers. Once you adjust that, reset all your float levels.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-01-2016, 09:28 AM
