Crankcase scavange line fitting part numbers
Guys I am looking for the 2 part numbers for the fittings that screw into the case I think there is a pre 73 number and a post 73.. They just are different outlet sizes. Any help would be appreciated
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
90013601302. Through 71
99913600809. 72 on Bruce |
Thanks looks like the early one is nla.. Any ideas?
I think I might have one in the drawer, I'll check tomorrow.
Bruce |
The funny thing is I use to as well.. So I will clue you into what I am doing.. I am making aluminum oil tanks for 914-6 conversions and want to use 22mm thread in fittings because lots of options from there.. These would be a perfect solution
![]() Here is a quick shot of the internals
I did a 914/6 conversion on a 70 in 1980. I recall the oil tank and the scavenge line around the front.
Bruce |
Yup but these are just for the tank fittings
I gave it a general look, not seeing early ones
They show up when there is no longer interest... Bruce |
Schleprock
If you're planning on using AN fittings, or offering the option, for the tank or oil lines? You can use an M22 adapter with AN male hose adapter threads on it.
BAT has them in aluminum alloy http://97.74.32.155/files/metric.pdf You also see on that page they offer the all-metric adapter (M22 male port to M26 or M30 female spherical) Setrab makes one with AN-12 or AN-16 male and you can get them from Elephant or Pegasus Elephant Racing | Oil Hose Adapters, Unions, and Fittings | Porsche 911/930 https://www.pegasusautoracing.com/productdetails.asp?RecID=8840 Setrab also makes a direct-fit adapter that is an M22 port fitting with a built-in 90 degree swivel & male AN-12 flare. https://www.pegasusautoracing.com/productdetails.asp?RecID=8898
Kevin L '86 Carrera "Larry" |
Kevin long time no see.. I did check out bat.. Will keep that in mind for the future.. I was able to order 1 of each from Jim Ellis porsche in Georgia.. I may just make a bunch of fittings moving forward
Schleprock
Yeah Ben it's been a long time since the winter sucks party at EuroEast in Battle Creek, MI back in the day, eh?
BAT is good people to work with. Their ordering process is a bit antiquated but they know their stuff and handle your order very efficiently.
Yup now we are just a bit older and know better.. I will contact Bat
