I am my 911's PO
Diagnostic process
At a DE car suddenly down on power and making unhappy noises. I shut it down and coasted to garage. Once it's towed home, what should I check? Turn it over by hand? Pull valve covers and inspect? Compression and leakdown? Oil filter contents? Short of a full tear down what should I look at first?
I am my 911's PO
visual inspection
First things first - visual inspection. This is #5. Is that the base gasket protruding? Can broken head studs cause that?
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
A broken stud doesn't bring it down on power necessarily but jumping time on a cam can cause problems and still get you home.
Put car up on one side and pull lower valve cover and take a look. More than 1 broken stud, broken rockers, rockers shafts moving off location, rocker falling off the shaft. Bruce |
I am my 911's PO
Thanks for the guidance, Bruce. I'll pull the valve cover first thing tomorrow.
Already drained the oil. Metal on both magnets. That is the base gasket - I can slide it up and down, so the cylinder is quite loose. Thanks again, Bruce. |
Lots of junk on the magnet, a rotational clicking, you're probably looking at spun bearing on a rod. This failure eats up the crank very quickly and it's expensive to repair.
Just start taking it apart until you find the defect or if you're unsure of your work, send it out. Bruce |
I am my 911's PO
oil drain plug debris
Chunks on magnets, check.
![]() That's the oil tank plug on the left with the big chunks. They're flat and 1.46mm thick. Piston ring fragment? If so, how would they migrate from the crankcase to the oil tank? Wouldn't that require getting past the oil pickup screen, through the pump and through the oil filter? I'll pull the valve cover this morning and see what's there. Stay tuned. |
I hear your thoughts. I have to admit I always thought it out as things can't get back to the oil cooler because all oil is filtered, sent to the reservoir as clean oil..sounds like my mistake.
You're going to have to flush the cooler lines, trombone, thermostat and send the cooler out for sonic cleaning. Another item. I don't see how you can have broken rings in the oil unless you blew up the piston or broke a valve and holed it tearing the ring grooves apart. I'm sure you still have to look at the rod bearings... Bruce |
I am my 911's PO
Pulled the right side exhaust valve cover. Headstuds intact. Rocker shafts have not moved. Rockers ok, but massive clearance on #5. Bent valve, right? Some FOD (foreign object, debris) in valve cover.
Probably time to quit poking around and just drop the motor for a tear down.
I am my 911's PO
You replied while I was typing.
If you bent the valve, you have to look for piston damage Worse scenario is a broken valve with hole in piston and rod bent. Seen that several times.
Bruce |
I am my 911's PO
Photos of carnage
Bruce, don't you ever get tired of being right?
Did this start as detonation? The piston top is gone above the first ring. What are the odds the crank is OK? ![]() ![]()
There is a broken rocker on intake 5.
Nice valve face on the piston where it hit. Looking for a reason, just looks like piston failure at the piston pin area Youll have to spin the crank at a machine shop to check for a bend or runout. Bruce |
I am my 911's PO
Case damage
Apparently the cylinder base lifted and bashed debris against the case. That's why the cylinder gasket was protruding and loose. Can the case be rescued? The damage to the surface where the cylinder sits is about 1mm deep. Can these (all 6, I presume) be re-machined and used with thicker base gaskets?
The answer is yes. I'm doing one right now on a 3.2 that was previously cut 1mm. Not knowing it was done until it was after the first assembly, I've had to take it apart a couple times to make things right. EBS has .25, .50, and 1.0 mm base gaskets.
I'll catch grief over it but I would only fly cut the one cylinder base, clean the case inside of defect and rebuild. Looks like you have alucil cylinders, as I recall old conversations, K&S pistons are cast, not forged, that may be why the piston blew up because of an inherent weakness. Bruce |
UnRegistered User
This kind of reminds me of the Far Side cartoon "Early Plumbers".
The caveman bending over the hole in the ground saying "Oooo, this not be cheap". Sorry to see that this kind of blew up on you but will be interested in the direction you need to go to repair.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I am my 911's PO
Bruce, cylinders are Mahle and magnetic. That means Nikasil, right?
I hear you about the case repair. Machining just one spigot should work so long as it is properly indexed off the others and the correct base gasket is used. In any event, I would certainly stamp the case. I saw the thread you posted with interference at TDC. Thanks, Bill. I intend to crack the case today and see the condition of the crank. |
It's $150 to deck all 6 spigots at a famous left coast machine shop. It can't be much less than that to set up and do just one. If you can deck it yourself, I guess it's more expedient to dress up that one spigot. If you have to send it out, it would make little sense at that price point to do just one. I personally would go into an OCD tail spin knowing one spigot was different from the rest.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Well, the situation is, everything will be different now....
It doesn't matter how much money you spend on the case, you can't make it perfect and you'll always be looking at the #5 base gasket area. What would you resolve cutting the other 5 cylinder bases, you'll still look at #5 every time you get under the car. My Raleigh machine shop can fly cut anything I need done, don't need to send it any further. I just hope his crank is still straight. Bruce |
I am my 911's PO
more carnage
Not what you want to see when removing the sump screen...
![]() This is most of the debris. I haven't raked out the crankcase yet. Of course, the insidious stuff is what has circulated through the lubrication system (internals, coolers, lines, tank...)
You ll have shrapnel in the FI intake too on both sides and the airbox because the junk was blowing up from the pressure in the engine and sucking in on the good cylinders.
Bruce |
