I am my 911's PO
'78 SC's Avatar
Thanks for the warning. Not obvious it would travel there.
I wonder how much fine stuff get blown through the crankcase vent to the oil tank. I imagine it's just a tornado of oil mist and pulverized metal.
Old 01-15-2016, 04:25 PM
I am my 911's PO
'78 SC's Avatar
Take a look at at these main bearings. Surprisingly little embedded metal, it seems.
Old 01-15-2016, 04:26 PM
Yes the mains actually look descent, not scratched through the rotation.
Bruce
Old 01-15-2016, 05:05 PM
I am my 911's PO
'78 SC's Avatar
Are the mains good enough to reuse?
Old 01-15-2016, 05:07 PM
There is 2 thought processes here. One to fix the fault and the other is to rebuild because you're there. The nice thing about the Porsche design is you can fix the fault.
You ll need a rod, P/C, head, rocker. Check the oil line in the carrier for damage from the rocker.
Remove the mains and mark exactly where they came from in the case to be reused.
Cleaning will be the biggest problems. Oil galleys in the case, galleys in the crank, how scratched up inside is the oil pump?
Etc, etc
Bruce
Old 01-16-2016, 02:06 AM
Tom '74 911's Avatar
Originally Posted by '78 SC View Post
Oh my.
I think Bruce is correct. Cleaning is going to be at, or near, the top of the "difficult steps" list.
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-16-2016, 06:40 AM
I am my 911's PO
'78 SC's Avatar
junk getting into lubrication system
You said it, Tom. It's going to be a nightmare.
The old race cars had a filter called a "grenade" to keep debris from the external oil system. It's a magnesium casting with a stack of fine mesh filters inside that attached to the motor in place of the internal cooler. I think the name was partly due to its shape but mostly due to it role when an engine "grenaded".
Here's one on a 906 (just aft of #6).
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 01-16-2016, 01:18 PM
I am my 911's PO
'78 SC's Avatar
Spun bearing, right?
Old 01-16-2016, 02:36 PM
That's what they look like
Bruce
Old 01-16-2016, 03:02 PM
I am my 911's PO
'78 SC's Avatar
I'm sure there was a cheaper way to learn that. Wikipedia, maybe.
Old 01-16-2016, 03:06 PM
I am my 911's PO
'78 SC's Avatar
Here's the rod journal. No grooving I can detect with fingernail. Not glassy smooth like the others but not rough. Mikes out near low end of wear limit.
Old 01-16-2016, 04:19 PM
Oh, I could have showed you several pictures but you asked after the fact...
Polish out the journal and see if you can straighten it out making it usable then get coated bearings to build up the thickness.
Mike on three different angles to check for oval
Bruce
Old 01-16-2016, 04:28 PM
I am my 911's PO
'78 SC's Avatar
Someone suggested the crankcase spigot can be welded to build it up and machined back to standard height. Is that feasible? The damage is shallow (about 1mm at deepest) and extends about 1.5 inch.
Old 01-17-2016, 10:53 AM
A machine shop will heliarc the low spot and flycut it up to standard.
At that point you might consider using the thicker fiber base gaskets to fill in better.
Bruce
Old 01-17-2016, 11:08 AM
I am my 911's PO
'78 SC's Avatar
crankcase repair
OK, I've been slowly working my way through the process of assessing damage, locating replacement parts and cleaning, cleaning, cleaning.
Here's the crankcase after repairs. The repair inside the spigot is obvious, there were also small repairs to the top of the spigot.
Old 03-10-2016, 05:44 AM
I am my 911's PO
'78 SC's Avatar
metal in intake
Originally Posted by Flat6pac View Post
You ll have shrapnel in the FI intake too on both sides and the airbox because the junk was blowing up from the pressure in the engine and sucking in on the good cylinders.
Bruce
Right again, Bruce. Here's the bottom end of the #5 intake runner and the breather line from the case to the oil tank.
Old 03-10-2016, 05:54 AM
puddy's Avatar
The horror! So sorry to see this misfortune, best of luck getting her back in track shape!
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 03-10-2016, 07:05 AM
I am my 911's PO
'78 SC's Avatar
Thanks, Chris.
The clean up has been an enormous task. The whole oil cooling and circulation system had to come out to be flushed, swabbed and ultrasonically cleaned.
In the process, I explored areas I've never seen - here's the inside of the air box.
Note the metal flakes still present after flushing with carb cleaner and flooding twice with solvent. I had to open it up to really clean it.
The good news is I found my air leak.
That's the o-ring that seals the throttle body to the air box protruding.
Old 03-10-2016, 07:26 AM
You found your air leak, so it's all been worth it......in the end
Bruce
Old 03-10-2016, 09:24 AM
I am my 911's PO
'78 SC's Avatar
Yep, finding the air leak is a plus. I'm also having the crank drilled for better oiling and installing a 964 oil pump. Not sure I can stand this much fun again - at least not soon.
Old 03-10-2016, 10:21 AM
