gtc gtc is offline
abides.
gtc's Avatar
Number Eight Bearing Seal Sitting proud
After installing an Elring seal in my new Rauch & Spiegel #8 Bearing, the seal is sitting about 1mm proud of the face of the bearing. Will this cause a problem? Should it be flush? It won't go in any further without using a press.
I was able to install a Reinz seal flush in my original bearing with no trouble (before deciding to replace both just to be safe).
I did install the Elring seal dry (well, lightly moistened with rubbing alcohol), whereas I used Curil T on the Reinz seal which might have helped it slide in.
Graham
1984 Carrera Targa
Old 02-23-2015, 02:59 PM
gtc gtc is offline
abides.
gtc's Avatar
Here's a photo:
Graham
1984 Carrera Targa
Old 02-24-2015, 11:08 AM
I think mine looked the same. Not leaking.
John
"Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage
Old 02-24-2015, 11:35 AM
Normal.
206 637 4071
Old 02-24-2015, 01:57 PM
gtc gtc is offline
abides.
gtc's Avatar
Thanks, guys, that's good to hear.
Graham
1984 Carrera Targa
Old 02-24-2015, 02:47 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Next time use some water or spit or something that won't evaporate as fast as alcohol. "Temporary" lubricant like these lets the seal slide in a bit easier to avoid potentially tearing the rubber coating.
Also a good idea to put a few dabs of sticky grease on the garter spring behind the seal. Helps avoid the spring falling off when the seal is placed onto crankshaft snout.
Kevin L
'86 Carrera "Larry"
Old 02-26-2015, 09:21 AM
gtc gtc is offline
abides.
gtc's Avatar
Umm.... there's a spring back there?
It went in pretty easily. Not too worried about it having torn.
Graham
1984 Carrera Targa
Old 02-27-2015, 03:38 PM
Walt Fricke's Avatar
The seals on both ends of the crank have a circular coil spring which fits into a groove on the backside of the sealing lip. Holds tension on the lip.
I've not had a problem with it coming off, but doubtless Kevin speaks from experience. If something can go wrong, at some point it will.
Old 02-27-2015, 09:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The garter spring stays in place when the seal is evenly pressed in. But sometimes when people whack the seal in place with alternating blows it can hop off the seal. Better to be safe than sorry and it doesn't take much effort at all to put a few blobs of grease on the spring?
Kevin L
'86 Carrera "Larry"
Old 02-28-2015, 06:26 PM
gtc gtc is offline
abides.
gtc's Avatar
Ok, after taking a close look, i do see the springs in the seals.
One more question... do you guys install the flywheel seal on the crank before putting the crank in the case, like Wayne suggests in his book, or do you install it afterwards?
Graham
1984 Carrera Targa
Old 03-02-2015, 09:47 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Afterwards. Setting the case halve in your hands down onto the receiving halve takes some coaxing and I don't like the idea of the flywheel seal being one more obstruction to getting the case halves nicely kissed together.
Kevin L
'86 Carrera "Larry"
Old 03-02-2015, 09:54 AM
gtc gtc is offline
abides.
gtc's Avatar
Thanks, that makes sense.
Graham
1984 Carrera Targa
Old 03-02-2015, 03:05 PM
The guy who taught me to assemble these motors favored leaving off the seals on each end also. His rationale was that they produced a bit of resistance to crank rotation, and he wanted to be able to verify that the crank was free as a bird after he had put the halves together, and even more after torqueing things down.
Kevin's approach makes a bit more sense, as I don't think you could tell when rotating the crank by hand whether there were seals in place or not. Besides, my guru didn't apply his approach to the #8. I hate installing seals, so doing the #8 on the bench is an easy decision. But I continue to leave off the #1.
Old 03-04-2015, 11:37 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I got these seal press tools in a lot of tools for a nice price. They work great but are certainly not an absolute must to get the seals installed right.
Kevin L
'86 Carrera "Larry"
Old 03-04-2015, 01:17 PM
I used the arbor to. Worked great.
John
Old 03-04-2015, 01:27 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The big one works great for sure. It's one of those tools where you say, "Wow. Total overkill but it sure does work good."
Kevin L
'86 Carrera "Larry"
Old 03-04-2015, 01:54 PM
abit off center
cgarr's Avatar
^ so you got that engine back together?
______________________
Craig
G2Performance
Old 03-04-2015, 05:38 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Nope
Kevin L
'86 Carrera "Larry"
Old 03-05-2015, 03:35 AM
silver911rdb's Avatar
So what's the deal with these Rauch & Spiegel #8 bearings. Are they better than the oem bearings? I was just working on my rebuild shopping list and noticed this offering. I never heard of them before and only found this thread related to them. Wondering if I should consider them for my engine rebuild. It's a 3.4L track engine.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 01-24-2016, 03:20 PM
Air Medal or two
afterburn 549's Avatar
Graham
When did you start this?
This for your Targa?
What happened?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-24-2016, 04:23 PM
