Targa Time's Avatar
Engine Shroud Painting
With everything looking so clean and pretty with the rebuild, my red engine shroud appears a bit tattered. Has anyone painted their shroud? If so what kind of paint and how well did it last?
Old 03-02-2011, 12:23 PM
Max Sluiter
Flieger's Avatar
The red is gel-coat. You should be able to sand and polish it to a nice bright finish.
Old 03-02-2011, 02:07 PM
83 911 Production Cab #10
JJ 911SC's Avatar
T.T.
How clean??? We need pics...
Check my thread for paint suggestion; http://forums.pelicanparts.com/paint-bodywork-discussion-forum/587240-engine-shroud-painting.html
Who Will Live... Will See
Old 03-02-2011, 02:31 PM
Arrow Wrinkle Finish Black
Dupli-color Wrinkle Finish Black - Very Durable - Shroud, Fan Housing and Upper Valve Covers. (I know my short arm linkage was disconnected during this photo)
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 03-02-2011, 08:55 PM
Shane
I think they (shroud & valve covers) came out fantastic! By the way, what plug wires are you running?
Dave
Dave
'75 911s Coupe
Old 03-02-2011, 10:39 PM
D911SC's Avatar
Dave
They're Clewett's.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 03-03-2011, 02:07 AM
JJ 911SC's Avatar
Originally Posted by D911SC View Post
They're Clewett's.
Available here, in Black or Red Pelican Parts - Product Information: CE-9192-20-R
Old 03-03-2011, 02:28 AM
Daviboy's Avatar
I rubbed mine down and then treated with a basic high temp primer and high temp red engine paint. It came out looking good and seems to be holding up well.
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 03-03-2011, 05:39 AM
Less brakes, more gas!
euro911sc's Avatar
Krylon is your friend. so is search Lots and Lots of threads on this
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-03-2011, 05:54 AM
I hate the thought of painting a red shroud or green one.
I do love the crinkle look
This is the shroud when I took the engine apart and then when a friend said he had nothing to do for the weekend. He brought this back....
Bruce
Old 03-03-2011, 06:42 AM
I'd like to paint mine while its all apart but its plastic. Are they all plastic? Until recently I thought they were metal. So what sort of paint should we be using?
Old 03-03-2011, 07:34 AM
Max Sluiter
Flieger's Avatar
They are all fiberglass.
Old 03-03-2011, 09:40 AM
Arrow durable an even krinkle finish
The key to a durable an even krinkle finish is;
- a clear, hot sunny day
- prep the surface of the shroud by scuffing with some 80 grit
- preheating the can in warm water to warm the paint about 85-90 deg F.
- one even light coat (allow to dry about 10 minutes or until tacky)
- then one thick coat
- place the whole thing in direct sunlight ( I put my valve covers in the oven on lowest setting with the door open for about 20 minutes, the shroud had to sit in the sun for a couple of hours before it wrinkled)
Old 03-03-2011, 05:48 PM
Arrow
Dave
Thanks Dave,
As mentioned, They are Clewetts, these are great plug wires. I ordered from Clewett directly and received great service for this custom set. I ordered a set with a longer coil to distributor wire because I relocated the coil into the accumulator spot. The wires fit is perfect and they are easy to go on and off with an audible click when properly in place. The rubber boots are very secure and fit perfectly into the recesses.
Highly recommended,
Shane
Old 03-03-2011, 05:57 PM
Targa Time's Avatar
Flat6Pac
Did your friend use auto body polish? Came out looking almost new.
Old 03-04-2011, 03:50 AM
He said he used the purple stuff. I had already removed the loose grease with the cleaner and brushed and left stains. I thought some polish would work but there was nothing like Gary gave me back..
Bruce
Old 03-04-2011, 04:54 AM
Targa Time's Avatar
One thing I know for certain is that I have NO talent when it comes to computers. I tried to add a couple of pictures for JJ 911SC entertainment assuming it would be like adding pictures to a E-Mail. No such luck. Can anyone give me a step by step on how to post a picture on a established thread?
Old 03-07-2011, 06:18 AM
JJ 911SC's Avatar
TT
Put the photo on your desk top and PM me your phone #.
Cheers
J.J.
Old 03-07-2011, 09:13 AM
Lightbulb Safari
I can not load a photo using internet Explorer on this forum. For some reason I can only load a photo using Safari.
Perhaps you should try Safari as your browser.
Shane
Old 03-07-2011, 12:11 PM
Max Sluiter
Flieger's Avatar
1. Hit post reply to bring up the advanced window (not the quick reply).
2. Enter the message part of your post until you get to the spot you want the image to appear.
3. Look below the text editor window but above the smilies and click "Click here to Upload a Photo..."
4. Browse for the file on your computer (gif or jpeg only)
5. Click "Upload Now"
6. Click "Submit Reply" below the smilies.
OR
Use a photo hosting site like flickr and embed images and videos.
Old 03-07-2011, 01:55 PM
