wprater's Avatar
factory manual image for rebuilding 930 tensioners
I'm looking for rebuild/install instructions for the turbo chain tensioners.
I've got the rebuild kit 911.105.901.01 but the instructions I found don't have images and I can't recall where that little ball goes.
anyone have some images/text from factory manual for rebuilding these?
1971 911T (Tangerine)
1973 911T (Light Yellow)
1978 911SC -- "Northy" 3.2 twin plug
1990 911 Carrera 2
Old 02-16-2016, 06:25 PM
Alan L's Avatar
I don't think the manual has any instructions for rebuilding them. The manual only has stuff specific to the 930. The tensioners are not unique to the 930.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-16-2016, 08:08 PM
Banned
I found this by doing a google search for "930 cam chain tensioner exploded view" - not sure it helps you, though . . .
Old 02-16-2016, 10:50 PM
wprater's Avatar
[QUOTE=Ronnie's.930;9001098]I found this by doing a google search for "930 cam chain tensioner exploded view" - not sure it helps you, though . . .
that's the later style Carrera pressure fed tensioner. I like the "exploded view" keywords, will try that.
1990 911 Carrera 2
Old 02-16-2016, 10:54 PM
I think this is what you are looking for:
andy
Old 02-17-2016, 04:11 AM
wprater's Avatar
thanks Andy! that's great, but I think that for an earlier version the 901 vs the thin boss late 930. it's missing the little spring to hold the ball.
do you have another ?
1990 911 Carrera 2
Old 02-17-2016, 10:40 AM
wprater's Avatar
found it. would be nice it it had descriptions, like yours. so if you do have a copy, feel free to post it here!
1990 911 Carrera 2
Old 02-17-2016, 11:04 AM
wprater's Avatar
here is a pic I took with the parts laid out. I'm rebuilding now.
1990 911 Carrera 2
Old 02-17-2016, 02:52 PM
Banned
Good info!!
Old 02-18-2016, 06:15 PM
safe's Avatar
This exploded view is in the Haynes manual.
Someone of the engine gurus here has also written an instruction, like 10-15 years ago. I remember that I found them when I did this.
Old 02-18-2016, 11:05 PM
wprater's Avatar
I made this little M6 tool to help hold the plunger down
1990 911 Carrera 2
Old 02-19-2016, 10:22 AM
faverymi's Avatar
[QUOTE=wprater;9004632]I made this little M6 tool to help hold the plunger down
Great info!
Is this the only special tool needed for the job? Besides the rebuild kit?
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 02-20-2016, 06:49 AM
wprater's Avatar
I also bent an old top spring which I used to push the little ball down. this allows you to continue to fill the chamber with oil until it's stiff.
1990 911 Carrera 2
Old 02-20-2016, 09:44 AM
